KICKER or SONY amp ?
Old Jun 21, 2005 | 07:50 PM
89dohcEF's Avatar
Default KICKER or SONY amp ?
http://cgi.ebay.com/ws/eBayISA...=STRK
KICKER-300w amp 2channel for 90 shipped
OR
Sony-480w amp 2 channel for 84 shipped
hmm help me make a decision, is going to power 2 6.5" infinity kappa components and 2 3.5" infinty speakers
Old Jun 21, 2005 | 10:38 PM
89dohcEF's Avatar
Default Re: KICKER or SONY amp ? (89dohcEF)
anynoe care to give a ****?
Old Jun 22, 2005 | 12:12 AM
BEE1's Avatar
If i were to pick from those two i'd definitely go with kicker over sony. IMO sony is overrated in the automotive electronics industry
Old Jun 22, 2005 | 04:07 AM
SCIVIC94's Avatar
IF YOU ARE LOOKING TO POWER FOUR SPEAKERS WHY ARE YOU LOOKING AT A TWO CHANNEL.YOU SHOULD BE LOOKING FOR A FOUR CHANNEL.YOU WILL BE ABLE TO SET UP YOUR SOUND STAGE BETTER THAT WAY.THE 3.5"SPEAKERS ARE NOT GOING TO HANDLE THE POWER YOUR 6.5"CAN.SO YOU ARE GOING TO OVER POWER ONE SET OR HOLD BACK THE OTHERS FROM NOT ENOUGH POWER
Old Jun 22, 2005 | 06:30 AM
hometheaterman's Avatar
Default Re: KICKER or SONY amp ? (SCIVIC94)
Yup if picking from those definately Kicker. Stay away from Sony.
Old Jun 22, 2005 | 11:56 AM
DvD3's Avatar
B A N N E D
sony sucks the left nut
Old Jun 23, 2005 | 12:38 AM
dc24me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SCIVIC94 &raquo;</TD></TR><TR><TD CLASS="quote">IF YOU ARE LOOKING TO POWER FOUR SPEAKERS WHY ARE YOU LOOKING AT A TWO CHANNEL.YOU SHOULD BE LOOKING FOR A FOUR CHANNEL.YOU WILL BE ABLE TO SET UP YOUR SOUND STAGE BETTER THAT WAY.THE 3.5"SPEAKERS ARE NOT GOING TO HANDLE THE POWER YOUR 6.5"CAN.SO YOU ARE GOING TO OVER POWER ONE SET OR HOLD BACK THE OTHERS FROM NOT ENOUGH POWER</TD></TR></TABLE>
the amp is 2 ohm stable in stereo. wire two 4 ohm speakers in parallel, you get a 2 ohm load.
the amp it puts out 75x2 at 2 ohms.
each speaker sees half of that.
most aftermarket speakers can handle 30-40 watts of rms power so he might not hit the thermal limit.
you're right through, because he has a set of 3.5" speakers he might hit the mechanical limit of the speaker unless he throws a cap in line with the 3.5" (200Hz hp cap or a bassblocker), as he probably wants to have the 6.5" components play full range.
an alternative would be to ditch the 3.5" speakers for a box of dynamat for the 6.5" speakers in the door
Old Jun 23, 2005 | 04:00 AM
SCIVIC94's Avatar
BY THE WAY,YOU NEVER SAID WHAT KIND OF CAR THESE ARE GOING IN AND WHAT KIND OF SOUND YOU ARE LOOKING FOR.
Old Jun 23, 2005 | 08:48 PM
numbnuts22715's Avatar
sonys SUCK...
definately get Kicker or something like that.
I know that Kenwood and Pioneer make decent ones.. way better than a sony.
Old Jun 24, 2005 | 02:22 PM
92BluEH-3's Avatar
lulz
well i would go with the kicker definatly. sony sucks ballz. but if it were up to me i would go with an orion. but that would blow **** up. and they are really expensive so kicker definatly.
KrazoMike
Audio / Security / Video
20
Dec 1, 2011 06:46 AM
davidhseo
14
Nov 9, 2010 08:51 PM
zeusone2
Dec 27, 2009 10:33 AM
Jintegra99
Oct 1, 2004 03:34 PM
deeweezy
Jan 14, 2004 09:36 PM
