Kicker l5
Old Mar 18, 2009 | 12:22 PM
deerman2701's Avatar
Default Kicker l5
So i have a kicker l5 i just bought and around the corners there seems to be like clue and on the corner there is a tear on the black part is there a way to fix this or should it not make the sound that bad?
Old Mar 20, 2009 | 12:37 PM
B18C_EJ8's Avatar
Default Re: Kicker l5
I really didn't understand a word of that...
Are you saying that the foam/rubber "surround" (black ring of flexible material around the center cone) is ripped/glued?
If so, use some silicone, make your repair, and let it cure for a couple of days.
Should sound fine as long as there's no air leaking from the front to the back or vice/versa.
Old Mar 20, 2009 | 02:02 PM
Sorry yea that part it seems to be glued on all four corners it still gives but its there and on one corner there is a tear so is it ok to just play it with the tear of will it sound bad and get worse
Old Mar 20, 2009 | 03:51 PM
fcm's Avatar
fcm
Old Fart
It will sound bad and get worse.94
Old Mar 23, 2009 | 06:09 PM
96 EX's Avatar
I once used fiberglass and apoxy resin to seal a 15' kicker up. It worked, definetly not for show though. Like stated it will sound bad and progressively get worse. Now days you can get **** brand new off of ebay for a 1/3 of the price.
Old Mar 24, 2009 | 04:52 AM
doggworld1233's Avatar
i have used black RTV on speaker foam and so far it has worked great for me
Old Mar 29, 2009 | 10:49 AM
Who would you trust more hifonics or power acoustik for an amp there both 600 rms one is 2 channel and other is mono
kTrain89
Dec 26, 2011 06:35 PM
yoyosupmang
Honda Civic (2006 - 2015)
Jun 5, 2007 01:02 PM
People_Mover
Feb 9, 2007 12:24 PM
__oversea
Welding / Fabrication
Apr 27, 2006 02:55 PM
