kicker amp and two kicker cvrs
Old Feb 1, 2007 | 10:00 PM
TANKE92113's Avatar
Default kicker amp and two kicker cvrs
i have one of the new kicker zx amps and it is the 550.3. t actually is a three channel amp and i was wondering if it would be ok for two cvrs at 2 ohms
Old Feb 2, 2007 | 12:38 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: kicker amp and two kicker cvrs (TANKE92113)
models would be nice, 10 or 12 ?
Old Feb 2, 2007 | 10:38 PM
TANKE92113's Avatar
12 inch sorry
Old Feb 3, 2007 | 03:23 AM
RICO_'s Avatar
NO MERCY!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TANKE92113 &raquo;</TD></TR><TR><TD CLASS="quote">i have one of the new kicker zx amps and it is the 550.3. t actually is a three channel amp and i was wondering if it would be ok for two cvrs at 2 ohms</TD></TR></TABLE>
Probably not. That amp is designed to power 2 door speakers and 1 subwoofer, which is what the Class D 3rd channel is for. Power output at 2ohms is 85W RMS for 1st and 2nd channel and 420W RMS for the sub channel. Although you might be able to bridge the sub channel to power two subs so I could be wrong. Not sure though.
Old Feb 3, 2007 | 08:49 AM
fcm's Avatar
fcm
Old Fart
Although I agree with RICO, [probably not] just not for the same reason, you can run as many subs as you want off the one mono sub channel as long as the final load of the subs is not below 2 ohms, however the CVR12" is a 400W continuous, [RMS] sub for 2 of them you would need 800W RMS to drive them properly, but then again if they are DVC 4 ohm subs, it would drive one of them perfectly, 1x420W RMS into a 2 ohm load. 94
Old Feb 3, 2007 | 08:35 PM
TANKE92113's Avatar
Default Re: kicker amp and two kicker cvrs (fcm)
rhanl you i was just wondering because i already have them. plus i got a good deal on the amp. ohh by the way the certificate on the box of the amp said max power 747 watts
Old Feb 4, 2007 | 07:18 AM
fcm's Avatar
fcm
Old Fart
The operative word there is max and really means nothing, when matching speakers to amps, [amps to speakers] you need to look at the RMS power of the amp and the continuous power handling of the speakers.
Please understand, the amp will drive the 2 subs all day long without any problem, powering a speaker, [or pair of speakers] with less then their rated continuous power handling will not hurt the speaker(s) you will just not get the full potential output of the speaker(s) the phrase "under-powering speakers is bad for the speaker" is an inaccurate statement, it's not the under-powering that hurts the speakers, it's driving an under-powered amp to constant clipping that hurts the speaker, besides sounding like kaka.
With that amp the sub bass would sound better using one of the subs, you would get better, cleaner, tighter sub bass from one of them then you would with both of them.
Another thing I need to know is what are they, DVC 2 ohm or DVC 4 ohm subs, a single DVC 2 ohm would have the same problem as two DVC 4 ohm subs. they can't be wired for amps optimum output. 94
Old Feb 4, 2007 | 01:44 PM
TANKE92113's Avatar
dvc 2 ohms subs
Old Feb 4, 2007 | 03:35 PM
fcm's Avatar
fcm
Old Fart
Two DVC 2 ohm subs can be wired to a .5 ohm, 2 ohm or an 8 ohm load, wire them to a 2 ohm load and use both of them, just be careful not to overdrive the amp into clipping. 94
Old Feb 5, 2007 | 02:26 PM
TANKE92113's Avatar
would i still be able to use them them without any distorton or any other weird things
Old Feb 6, 2007 | 06:21 AM
fcm's Avatar
fcm
Old Fart
Yes, just as long as you do not overdrive the amp into clipping. 94
Old Feb 6, 2007 | 09:52 AM
RICO_'s Avatar
NO MERCY!
Just know you're not gonna get full power out of the subs. Your channel isn't powerful enough for it. If you do you'll probably wanna get a separate amp for the TWO CVRs like a Kicker 750.1 or 1000.1. But it will still sound good. Just don't get too bass-happy.
Old Feb 6, 2007 | 01:59 PM
TANKE92113's Avatar
Default Re: kicker amp and two kicker cvrs (RICO_)
i appreciate it im going to het them installed for now and then ill get another amp
thanks again
sumdewd
Audio / Security / Video
May 17, 2012 05:22 PM
imadigitalgod
Jul 30, 2006 08:54 PM
is3oo
May 5, 2006 12:13 PM
EVIL_AWD
13
Jul 18, 2003 12:14 PM
redteg1
Apr 9, 2002 08:46 PM
