Keyless Entry Module
Old Jun 11, 2024 | 04:15 PM
coachroy's Avatar
Default Keyless Entry Module
I have a Canadian 2000 Civic Si and from what I can tell, the module is supposed to be under the driver side left kick panel but the slot is empty. I have power locks. Is there somewhere else the Canadian Civic Si would have this module? It seems like at some point there was some form of aftermarket unit installed. Not sure if it was power locks or just an alarm as I never got a key fob with the car. Would an install company typically remove the OEM module when they went to install an aftermarket one?
Cheers
Old Sep 19, 2024 | 03:00 PM
EK_Capelas's Avatar
Default Re: Keyless Entry Module
Hello.
was wondering if you figured out your keyless module issue. I have a Canadian 2000 EK that I did a power window and door lock swap. Can’t get my keyless remote to work. Not sure if you need the module for the door locks or if it’s only for the keyless remote.
thanks in advance.
Old Sep 19, 2024 | 03:37 PM
coachroy's Avatar
Is your keyless remote factory or did you purchase aftermarket? You will need the OEM keyless module or you need an aftermarket unit. My OEM unit was removed for whatever reason but I had an aftermarket alarm unit that was wired to also use the key fob to lock and unlock the doors. Luckily I was able to get a remote from Amazon and after a few tries, I was able to get it programed.
Old Sep 19, 2024 | 05:10 PM
EK_Capelas's Avatar
Thanks for the response. I’m going to try and find an OEM module and order a remote from Amazon.
tctruong94
18
Jan 31, 2012 01:23 AM
allmotorb18c14door
Jan 19, 2010 04:53 PM
projectpd
Apr 29, 2007 02:49 AM
ny153
Oct 18, 2006 11:40 AM
ilario
Audio / Security / Video
Mar 10, 2003 03:53 PM
