Keyless Entry Installation Help
Good afternoon, I am in the last stages of completing my keyless entry into a 93 accord LX 4DR 5-speed using a "Ready Remote Model 21994"
My question(s) are where are the dome light wires and where are the horn wires located as well as parking light??
and as always thank you for your time!
Parking lights: Red/Black (+) (fuse box, steering column, or driver kick-harness to rear of car)
Horn Light green/blue OR Gray OR Blue/red (-) (3 different wire color possibilities. Found at steering column harness or horn relay. Might need a relay to provide enough ground current)
Dome light (I'm assuming so it will turn on when you unlock)
Use door trigger
Black/white (-) (brown connector above fuse box. Possible relay required for enough ground current)
Use door trigger
It's your cars main anti theft box that sends signal to your cars computer in the event of possible theft I just cant figure out if when flashing red and green if it's been engaged or not
sir yo!
Sep 17, 2012 02:55 PM
