jvc wont work
i recently baught a jvc in dash cd player from a friend of mine and its not working. i know it worked before because i took it directly out of his car. the white and blue wire is the power wire from my car and the red n black is ignition and the yelow and red is the illumination i believe. i went to tweeters and asked the guy there what wires went to wut wires in my car. i hooked it up like he said and it wont turn on. i checked the fuses in the car and deck and they look fine. does anyone know anything else that may b wrong? theres a red, yellow and orange with a white strip on it. those are the power wires. any suggestions thanks-Allen
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hookedonvtec »</TD></TR><TR><TD CLASS="quote">i recently baught a jvc in dash cd player from a friend of mine and its not working. i know it worked before because i took it directly out of his car. the white and blue wire is the power wire from my car and the red n black is ignition and the yelow and red is the illumination i believe. i went to tweeters and asked the guy there what wires went to wut wires in my car. i hooked it up like he said and it wont turn on. i checked the fuses in the car and deck and they look fine. does anyone know anything else that may b wrong? theres a red, yellow and orange with a white strip on it. those are the power wires. any suggestions thanks-Allen</TD></TR></TABLE> The red is acc.,the yellow is constant, and the orange/white is illumination. if you have already cut off the OEM radio plur go to http://www.installdr.com for wire guide for your car, also, did you check the 7.5 amp fuse in the engine bay fuse box?
94
94
Sherm
Audio / Security / Video
Sep 23, 2006 12:07 PM
EFing8
Nov 14, 2002 03:27 PM
