just one question...
Old Oct 31, 2005 | 09:44 AM
pete griffen's Avatar
Default just one question...
is it possible to have a good sound output with a setup that includes: a Pioneer AVIC-D1, Mb quart for speakers, kicker for sub, jl for amp.
Old Oct 31, 2005 | 09:57 AM
MLD211's Avatar
Default Re: just one question... (pete griffen)
Anything is possible, Sounds good to me. You will probly want to amp those mb quarts tho.
Old Oct 31, 2005 | 10:34 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MLD211 &raquo;</TD></TR><TR><TD CLASS="quote">Anything is possible, Sounds good to me. You will probly want to amp those mb quarts tho.</TD></TR></TABLE> Ditto that, I will add that the install will have a lot to do with SQ, everything from speaker mounting, to sub cabinet, to wiring will have an effect on SQ.
You have, IMO, good equipment, a proper install will get the most out of it, on the other hand, cutting corners in the install at best will not allow the equipment to work to it's full potential, and at worse, can damage that equipment.
A common cause of "blown" speakers, [including subs] or damaged amps and HUs is poor install methods, improper mounting and/or wiring of equipment, I have replaced more then a few subs just because they were in an improper box, [wrong size or poorly constructed] and the most common problem I see is improper setup.
Take your time, do it right, it will sound great and last a long time. 94
Old Nov 2, 2005 | 09:07 AM
sleeperteg's Avatar
you should check and see the voltage of the pre outs of that unit. pioneer is kinda weak in that area and this will affect overall sound quality and performance when building a system. i remember the avic-n1 only had like 2.2 v. you should look at alpine or eclipse... get up to 5 or 8v if you can.
Old Nov 3, 2005 | 01:24 PM
Carbonciv's Avatar
ok put the Pioneer system up to your ear and tell me how it sounds, it doesnt put out any noise at all, it all depends on your amp, and your speakers, I hope your going to amp those MB Quarts cuz you might blow them due to under power.
nyzd79
Audio / Security / Video
Jan 18, 2008 02:58 PM
CrazyModGSR
Dec 9, 2007 11:56 PM
pearlwhitecrx
Northern California (Sales)
Oct 18, 2005 09:34 PM
Manolo
Jun 30, 2005 12:11 PM
ilikemyaccord
Aug 10, 2004 11:47 PM
