Just installed my system, problem?
Old Dec 29, 2003 | 06:36 PM
pbcdb's Avatar
Default Just installed my system, problem?
Hey I just installed my system and it sounds like ***. I have a pioneer deck a Rockford 301 amp(40 x4), Rockford Fanatic P components in front (6.5), and Fosgate FRC4206U in back (6.5). It seems like all I here is the rear speakers, I have to fade deck to 10 in front just to hear the componets over the rear speakers. All the speaker wiring is correct, And it seems like whenever I have the bass up on hard rock songs I can hear the rear speakers bottoming out a little. Also pasangers in the back complain about the tweets being to harsh. Right now the speakers are free air because I am in the process of installing fatmat. Idk what the problem could be I've tried all sorts of EQ postions on the deck and they all seem shitty. The fronts don't sound bad at all they are just to quiet or the rears are too loud. I tried sitting in the rear and I could hear the symbols over the singer. Should I scrap the rear speakers and go for some type r components? Would that change anything or would the rear speakers still be alot louder than the fronts. BTW I plan on getting 2 10 inch type s's in the near future.
Old Dec 29, 2003 | 07:38 PM
Oblivion's Avatar
I would switch the back to the front, reset your EQ's to the back more and get those 2 10's. should saound a bit better then.
Old Dec 29, 2003 | 07:56 PM
pbcdb's Avatar
Default Re: (Oblivion)
That's funny cause I just went out and tried to do that. Problem is the rear speakers won't fit in the front and I already have spacers. And I already have a little hole in my door panel for the tweeter's wire. Btw I have a 92 civic si.
Old Dec 30, 2003 | 02:31 PM
GaRn's Avatar
ditch the rears, rear fill sucks anyways hehe..
Medek's Avatar
Default Re: (pbcdb)
did you check your gains on the amp? if its four channels then there should be 2 ***** that increase/decrease wattage on the side where the rca's imput (usually)
making a guess your rears are overpowering because of wattagee
p.s. a standalone EQ does wonders.. try ebay and look 4 pioneer deq-7600
oh snap.. i almost forgot.. make sure you didnt accidentally reverse the negative /w the positive on the rears... and proof read your amplifiers wireing diagram in the manual.. isw the rear accidntally bridged? it could bew so many things.. its hard to say w/ visually looking @ it.
Old Dec 30, 2003 | 08:39 PM
pbcdb's Avatar
Thanks for the help guys. Turns out the gain was turned all the way down on the front speakers. I could have sworn I turned it on and checked that when I installed it.
Old Dec 30, 2003 | 10:07 PM
another_crx's Avatar
Default Re: (pbcdb)
and it sounds even now?
Old Dec 30, 2003 | 10:30 PM
pbcdb's Avatar
Ya it sounds even, excecpt for the components in front sound a hundred times better than the coaxials in back.
SchwabVang
Audio / Security / Video
May 1, 2013 07:15 AM
digdug18
Jun 11, 2006 07:15 PM
FunkyR
10
Nov 26, 2002 10:02 AM
mr_mbuna
Sep 8, 2002 12:45 PM
pauken
Jul 31, 2001 10:26 PM
