JL c2-650x help??
Old Jan 5, 2012 | 09:10 PM
chinkieboy's Avatar
Default JL c2-650x help??
Anybody try or know if the C2-650x will fit into 2012 Honda fit???
Old Jan 10, 2012 | 06:32 PM
fcm's Avatar
fcm
Old Fart
Default Re: JL c2-650x help??
Not without mods.
The JL Audio C2-650x is an "over-sized" 6.5" speaker, it requires a 5.56" diameter mounting hole, [most Honda/Acura have 5" diameter speaker mounting holes] the speakers mounting depth is 2.44", stock will be just short of 2".
The Honda fit uses a "clip mounting system" the speaker is it's own speaker mounting bracket, no screws, it "clips" into place.
You will need to make some custom MDF mounting plates.
Make the plates as big and thick as you can and still be able to fit behind the door panel, router a 5.56" hole in the panel and mount the panel at the stock location so hole centers in the grill, wire and mount the speaker and install door panel, call it a day.
Things to keep in mind...
A speaker needs a flat surface to mount to.
A speaker needs an airtight seal around it's mounting hole.
The more mass a speaker is mounted to the better it will sound, and if that mass is wood, even better.
Make sure speaker magnet or back of speaker does not interfere with window operation.
Make sure speaker mounting plate and/or speaker does not interfere with reinstalling door panel
Make sure door panel does not touch the speakers cone or tweeter cone.
Good luck. 94
k1ngkev1n1
Jun 29, 2008 11:05 AM
Team PHATBOYZ
Audio / Security / Video
Nov 17, 2005 01:38 PM
HondaCrazy20
Sep 5, 2005 03:21 PM
sinister357
May 31, 2005 07:53 PM
ALF
Apr 15, 2003 03:52 PM
