Ipod installation problem....
Old May 21, 2005 | 07:49 PM
SH_Mon's Avatar
Default Ipod installation problem....
I was recently trying to install my Ipod into my 5th generation Honda Prelude. However, I'm running into problems with the sound ONLY coming out of only the front speakers. This is how I set up: I plugged my cables (red/white) into the AUX port/Line-in port, and when i play my ipod, only sound is coming out of the front speakers and I cannot adjust the volume. Is there anything I can do to make this work? Also, the headunit I am using is the Alpine CDA-7864 (kinda old). Thanks for any advice.
Modified by SH_Mon at 12:16 AM 5/22/2005
Old May 21, 2005 | 09:02 PM
fcm's Avatar
fcm
Old Fart
Default Re: Ipod installation problem.... (SH_Mon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SH_Mon &raquo;</TD></TR><TR><TD CLASS="quote">I was recently trying to install my Ipod into my 5th generation Honda Prelude. However, I'm running into problems with the sound ONLY coming out of only the rear speakers. This is how I set up: I plugged my cables (red/white) into the AUX port/Line-in port, and when i play my ipod, only sound is coming out of the front speakers and I cannot adjust the volume. Is there anything I can do to make this work? Also, the headunit I am using is the Alpine CDA-7864 (kinda old). Thanks for any advice. </TD></TR></TABLE> I'm not sure I understand how you have thd iPod plugged into the Alpine, ["AUX port/line-in port"] Are you using an adpt. that lets you use the changer input, [AI-Net port] on the HU as an AUX. input, or is the iPod plugged into one of the two sets of RCA pigtails on the back of the HU, [front and rear/sub. preamp OUTPUTS, (the rears can be switched to non fading sub. output]
You say ................
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SH_Mon &raquo;</TD></TR><TR><TD CLASS="quote">and when i play my ipod, only sound is coming out of the FRONT speakers and I cannot adjust the volume. </TD></TR></TABLE>
And you say..............
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SH_Mon &raquo;</TD></TR><TR><TD CLASS="quote">However, I'm running into problems with the sound ONLY coming out of only the REAR speakers. </TD></TR></TABLE> or does it mean that when you play the HU, [CD, AM/FM] you only get sound our of the rear speakers, and when you play the iPod you only get sound out of the front speakers, I could see this as being possible if the Ipod is plugged into the rear preamp outputs, let me know what you ment. 94
Old May 21, 2005 | 09:16 PM
SH_Mon's Avatar
Default Re: Ipod installation problem.... (fcm)
I'm sorry, I meant my FRONT SPEAKERS.
And yes, I have my iPod plugged into one of the two sets of RCA pigtails on the back of my HU.
Let me clarify the problem more. The sound is only coming from the 2 FRONT speakers, and when when I play my ipod, i can hear it while my tuner is on, and when my cd-player is playing (it sounds like its playing in the background).
Also, can you tell me more about this adapter? What does it do? Where can i purchase it from? I'm clueless. Thanks!
Modified by SH_Mon at 12:28 AM 5/22/2005
Old May 22, 2005 | 07:24 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SH_Mon &raquo;</TD></TR><TR><TD CLASS="quote">I'm sorry, I meant my FRONT SPEAKERS.
Modified by SH_Mon at 12:28 AM 5/22/2005</TD></TR></TABLE>Ok... you are pluged into an output, Alpine makes 2 adpt. for your HU, an iPod interface, [not sure if it will work with the 7864] and an AUX. adpt., [it uses the AI-Net port] check at http://www.alpine.com or go to your local Alpine dealer and ask them, for now though, unplug the iPod from the HU, so it doesn't do any damage. 94
JDM215
Mar 3, 2008 07:21 PM
biggjimmy7
Audio / Security / Video
Oct 15, 2005 08:09 PM
mikeds122
12
Jun 10, 2005 06:00 PM
shivern
Jan 15, 2005 05:43 AM
shivern
Jan 14, 2005 09:12 AM
