ipod to headunit trouble
Old Jan 26, 2006 | 09:41 PM
jerBEAR's Avatar
Default ipod to headunit trouble
Can someone tell me how to access the aux option on this deck? It seems like all the connections are right so far but somehow the ipod still doesnt play from the deck. What are the other ways to do this by spending as little money as possible. Thanx for the help.
The deck:
RCA's:
Back setup:
The connection:
TIA
Modified by flipinoy823 at 11:12 PM 2/6/2006
Old Jan 27, 2006 | 01:04 AM
john666's Avatar
Default Re: ipod to headunit trouble (flipinoy823)
off the bat change the rca/phono cable u got.. radioshack has it cat #42-2550
the wires/adapters you have might all connect together but i think there not the right
Old Jan 27, 2006 | 01:47 AM
Kangolbrand's Avatar
Default Re: ipod to headunit trouble (john666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john666 &raquo;</TD></TR><TR><TD CLASS="quote">off the bat change the rca/phono cable u got.. radioshack has it cat #42-2550
hey does a headunit have to say its compatible with a ipod or can you just plug that rca thing you show a picture of from radioshack into a head unit that has rcas for amp/sub? lmk thanks
Old Jan 27, 2006 | 01:50 AM
john666's Avatar
Default Re: ipod to headunit trouble (Kangolbrand)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kangolbrand &raquo;</TD></TR><TR><TD CLASS="quote">
hey does a headunit have to say its compatible with a ipod or can you just plug that rca thing you show a picture of from radioshack into a head unit that has rcas for amp/sub? lmk thanks </TD></TR></TABLE>
does not have to say compatible with ipod... if it have a aux input thats all you need.. there are afew different ways to get a aux input if your hu doesnt have one in the back or front. ie changer input can be converted to a aux input.
Old Jan 27, 2006 | 02:15 AM
how about a stock 00 si deck... i aready have the rca modual thing that taps in to the speaker wires to make out rca imputs for my amp but was wounder if your thing you posted be plug into that and the other into my ipod and ill be set?
Old Jan 27, 2006 | 02:22 AM
john666's Avatar
Default Re: (Kangolbrand)
PMed
Old Jan 27, 2006 | 04:55 AM
PMed back
Old Jan 27, 2006 | 09:23 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flipinoy823 &raquo;</TD></TR><TR><TD CLASS="quote">Can someone tell me how to access the aux option on this deck? It seems like all the connections are right so far but somehow the ipod still doesnt play from the deck. What are the other ways to do this by spending as little money as possible. Thanx for the help.
Heres the deck:
The connections on the back:
The rca's up close: (IN=left OUT=right)
The setup:
</TD></TR></TABLE>Your problem is you have the wrong adpt. you need one that also plugs into the CD changer port, the HU is not switching to changer mode, so the "audio buss in", [used for CD changer audio signal] is not turning "on" 94
Old Jan 27, 2006 | 10:14 PM
Znypar's Avatar
i have this, and i have used it to play the sound from movies on my laptop over the sterio (viewed by the passenger of course). anything with a headphone jack will work with it.
Old Jan 28, 2006 | 09:10 AM
fcm's Avatar
fcm
Old Fart
Default Re: ipod to headunit trouble (Znypar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Znypar &raquo;</TD></TR><TR><TD CLASS="quote">
i have this, and i have used it to play the sound from movies on my laptop over the sterio (viewed by the passenger of course). anything with a headphone jack will work with it.</TD></TR></TABLE>Not, the Sony unit will not switch to changer input mode unless it "thinks" there is a changer plugged into the changer port. 94
Old Jan 28, 2006 | 09:16 AM
Znypar's Avatar
i meant the rca. not necessarily the sony. i love my alpine for the Ai-Link AUX
Old Jan 28, 2006 | 10:11 AM
hapexamendios 2.0's Avatar
R.I.P.
dont know if this will help, but when i had the same RCA cords plugged into my older pioneer deck i HAD to use the <U>output</U> RCAs, it wouldnt work with the input, which i thought was odd, worth a shot
Old Jan 28, 2006 | 09:43 PM
gunmetalej's Avatar
you need a head unit with aux input and from what i see that radio doesnt have one. the inputs you have are for an amplifier so that you can amp the front and rear speakers. once you have a head unit with aux inputs it is very easy.
Old Jan 29, 2006 | 07:57 AM
fcm's Avatar
fcm
Old Fart
Default Re: ipod to headunit trouble (gunmetalej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gunmetalej &raquo;</TD></TR><TR><TD CLASS="quote">you need a head unit with aux input and from what i see that radio doesnt have one. the inputs you have are for an amplifier so that you can amp the front and rear speakers. once you have a head unit with aux inputs it is very easy.</TD></TR></TABLE>
He does not need a HU with an AUX input, [although it would make it easier].
He has one input, ["buss audio in"] it is for the changers audio signal, he has one pre amp output, [rear audio out] it is used for an amp, and is controlled by the fader "rear".
There are adapt. form suppliers like SoundGate, OEM, Blitzsafe, PAC and others including Sony themselves that will turn the CD changer "unilink port" and "buss audio in" into an AUX input. 94
Old Jan 29, 2006 | 12:53 PM
jerBEAR's Avatar
Default Re: ipod to headunit trouble (fcm)
So basically what im looking for is a cd changer plug with a headphone jack on the other side? Can I find one of these at my local Electronic Stores?
Old Jan 29, 2006 | 06:27 PM
lhd dc2's Avatar
On the back of that cd player it looks like the blue plug is the Aux input. You will need a cable with a head phone jack on each end, and then put the HU on Aux.
Old Jan 29, 2006 | 09:53 PM
Znypar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flipinoy823 &raquo;</TD></TR><TR><TD CLASS="quote">So basically what im looking for is a cd changer plug with a headphone jack on the other side? Can I find one of these at my local Electronic Stores?</TD></TR></TABLE>
dont let me confuse you. that is the case for alpine head units. my knowledge of HUs doesn't extend as far as that of the sonys.
Old Jan 30, 2006 | 07:41 AM
fcm's Avatar
fcm
Old Fart
Default Re: ipod to headunit trouble (DBtwo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DBtwo &raquo;</TD></TR><TR><TD CLASS="quote">On the back of that cd player it looks like the blue plug is the Aux input. You will need a cable with a head phone jack on each end, and then put the HU on Aux.</TD></TR></TABLE> It is not, the blue plug is the input for the "remote commander" a wired remote control
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flipinoy823 &raquo;</TD></TR><TR><TD CLASS="quote">So basically what im looking for is a cd changer plug with a headphone jack on the other side? Can I find one of these at my local Electronic Stores?</TD></TR></TABLE> Sorry, with Sony its not so simple, check with your local Sony car audio store they can tell you what you need, and may even have it in stock.
Old Feb 1, 2006 | 02:38 PM
Guru Designs's Avatar
* B A N N E D *
im sorry but your guys must be BLIND! look at the splitter he is using. he is using a female to male connector. now where he has the ipod connected to is considered either the center or the outer part of the female adapter. if he gets a male to male spliter it will work.... SHEESH!
Old Feb 1, 2006 | 03:59 PM
fcm's Avatar
fcm
Old Fart
Default Re: (tobe2be)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tobe2be &raquo;</TD></TR><TR><TD CLASS="quote">im sorry but your guys must be BLIND! look at the splitter he is using. he is using a female to male connector. now where he has the ipod connected to is considered either the center or the outer part of the female adapter. if he gets a male to male spliter it will work.... SHEESH! </TD></TR></TABLE>
If you had read all the posts you would have seen that I and others are not blind....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Your problem is you have the wrong adapt.</TD></TR></TABLE>
Others showed him the adapt. you are talking about, headphone to male RCAs, and if the Sony had a RCA AUX input that would be the end of it.
But as I have explained, even with that adapt. it will not work, unless the HU can be tricked into thinking that there is a CD changer plugged into it , [unilink port and the buss audio in] it will not switch to changer mode so the buss audio in will not turn on, you would get more sound by plugging the adapt. into the audio output. SHEESH! yourself. 94
Old Feb 1, 2006 | 04:36 PM
93civicsedan's Avatar
Default Re: (fcm)
i think you might be able to use this http://www.crutchfield.com/S-F...MSC02 or this one http://www.crutchfield.com/S-F...XA300 with most other HU besides Sony you can hook up your ipod with one or two cables. Sony unfortunately doesnt have much you can use for their HUs
Old Feb 1, 2006 | 04:41 PM
fcm's Avatar
fcm
Old Fart
Default Re: (93civicsedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93civicsedan &raquo;</TD></TR><TR><TD CLASS="quote">i think you might be able to use this http://www.crutchfield.com/S-F...MSC02 or this one http://www.crutchfield.com/S-F...XA300 with most other HU besides Sony you can hook up your ipod with one or two cables. Sony unfortunately doesnt have much you can use for their HUs</TD></TR></TABLE> Good job, you found the Sony unit and an aftermarket that will do the job. 94
PS I would go with the aftermarket one, made for iPod and has all the cables.
Old Feb 5, 2006 | 07:18 AM
Pvt Joker's Avatar
These adaptors that plug in the changer jack make it work with any audio source.
I'm doing the same thing with my stock Acura radio and a Sirius receiver.
Old Feb 5, 2006 | 08:56 AM
fcm's Avatar
fcm
Old Fart
Default Re: ipod to headunit trouble (Pvt Joker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pvt Joker &raquo;</TD></TR><TR><TD CLASS="quote">These adaptors that plug in the changer jack make it work with any audio source.
I'm doing the same thing with my stock Acura radio and a Sirius receiver.</TD></TR></TABLE> Of the 2 adaptors that 93civicsedan linked us to the Sony unit will allow you to hook up any audio source that has RCA outputs, [or you can get/make an RCA adaptor] however the MSC-02 is iPod specific 94
LAO
Jan 14, 2008 06:38 PM
CaMiKaZi
Audio / Security / Video
Sep 4, 2003 05:10 AM
abraunb16
Jul 12, 2003 09:55 AM
