Installing Trunk Lip Mount Antenna Question
Old Jun 14, 2007 | 07:43 PM
imadigitalgod's Avatar
Default Installing Trunk Lip Mount Antenna Question
I am going to install a trunk lip mount antenna on my car in a few days. It has coax cable running to it but im not sure where I should run it through.
Below is the only way I can figure out how to run the wire. The green line is the coax cable running from the antenna, down the gutter and below the tail light where i was planning on drilling a hole to run it into the trunk, up the side of the car and into the center console where the cup holders are.
Does anyone else have an idea to run it? I don’t see any other way to do it. I can’t just drop it directly into the trunk and have the lid close on it because it cant be pinched at all...
someone said that most hondas have a crack that i can slip it into but i dont know what they are talking about
Any input is welcomed
Old Jun 15, 2007 | 04:59 AM
B18C_EJ8's Avatar
Default Re: Installing Trunk Lip Mount Antenna Question (imadigitalgod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imadigitalgod &raquo;</TD></TR><TR><TD CLASS="quote">I can’t just drop it directly into the trunk and have the lid close on it because it cant be pinched at all...</TD></TR></TABLE>
The weatherstripping should have enough give so you can run it right into the trunk at the point you mount the antenna... I bet it doesn't pinch as much as you think it will...
Then, you can run the cable down the hinge and into the car that way...
Old Jun 15, 2007 | 05:30 AM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^.
The mounting bracket should have a "channel" in it just for that, so the coax ends up inside the weatherstrip. 94
Old Jun 15, 2007 | 06:38 AM
Default Re: Installing Trunk Lip Mount Antenna Question (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Ditto the above^^^.
The mounting bracket should have a "channel" in it just for that, so the coax ends up inside the weatherstrip. 94</TD></TR></TABLE>
it does have a channel but its not long enough to protect it from the weatherstrip; ill try to just run it inside tho.
Here is a pic of the base of the antenna(Its a Wilson 1000 Trunk Lip Mount)
Old Jun 15, 2007 | 11:45 AM
fcm's Avatar
fcm
Old Fart
The weather strip will not hurt the coax. 94
Old Jun 15, 2007 | 12:38 PM
I didn’t think so but some other people said it would so I searched for a new location for it but I just ran it to the hinge and it seems to work with it between the weather strip and the trunk lid.
I get my Cobra 148 GTL in the mail Monday. After a peak, tune and tuning the antenna, I should be golden
KSWEST
Audio / Security / Video
Dec 20, 2007 08:08 AM
imadigitalgod
19
Jun 2, 2007 07:57 AM
s2kkid
Nov 27, 2005 03:01 PM
sdchump
Oct 10, 2003 04:23 PM
