installing on stock deck
You will need a high to low converter if your amp doesn't have high level inputs. THis isn't the preferred way, but if you are running stock deck to other speakers this will be just fine for a sub.
It is not recommended. But it also depends on the type of sub and amp you are going to run. The stock radio only gives you like 15-20 watts if you go with an after market radio it can give you anywhere from 30-50 watts which will give you a bit more output when running an amp with sub so it will sound a bit better when you start cranking up your radio. If you had a stock radio you are limiting yourself of output from your amp and subs so it will sound low or like crap. But I say give it a go if your just wanting some bass to get you by!!
sorry im not a techincal loser when it ocmes to stereos. . im asking. ..you didnt know at one time either, or did you. or did ur mom have u like that cus i was smarter when i pulled out of her too.
davejj40
Audio / Security / Video
Mar 9, 2005 07:34 PM
L4NDO
17
Jul 20, 2002 10:42 AM
Reid
Oct 14, 2001 06:56 PM
