installing speakers to amp???
Old Oct 16, 2005 | 12:45 PM
Keangdawizes's Avatar
Default installing speakers to amp???
i have a 2 channel 400 watt amp and i only use 1 channel cuz i only have 1 sub. i was wondering with 1 channel could i connect both of my back speakers to it. if yes would the picture i drawn below be correct? please help me thanx. also which setting would i set of my crossover??
Old Oct 16, 2005 | 02:10 PM
noble4ws's Avatar
can you hook up the rear speakers regular, 1 on each channel, then bridge your sub between them
Old Oct 16, 2005 | 02:28 PM
fcm's Avatar
fcm
Old Fart
Default Re: installing speakers to amp??? (Keangdawizes)
What kind of amp, [make and model] is it not bridgeable into a 1ch amp for sub use.
As there is probably only one x-over switch, for it to work properly it would have to be set at LP, [low pass] but running your read speakers on low pass is not going to work, you may be able, [depending on amp] be able to run it in "tri mode" left and right , [2ch mode] to the rear speakers and bridged mono for the sub, [a passive x-over, low pass, would be needed for the sub at least, and maybe high pass for the rear speakers] 94
gizbirne
Audio / Security / Video
11
Jun 13, 2014 06:58 PM
Cody2289
14
Feb 11, 2008 09:28 AM
rutherfordhigh
Nov 15, 2006 08:20 PM
Brandon Chun
Sep 11, 2005 09:15 PM
JesseCRX
Aug 20, 2005 06:46 AM
