installing lights and siren in adyssee
Old May 30, 2008 | 10:08 AM
cmdm's Avatar
Default installing lights and siren in odyssey
I would love to get any advice and instruction as what emergency lighting and siren equipment I can buy and install easially into my 2008 odyssey. I would install leds, slim lighter, sirens and a keypad to control it all..
Modified by cmdm at 2:13 PM 5/30/2008
Old May 30, 2008 | 10:34 AM
B18C_EJ8's Avatar
http://www.galls.com
Old May 30, 2008 | 01:10 PM
cmdm's Avatar
Default Re: (B18C_EJ8)
I know about Galls. I was asking if anyone already installed these equipment in an odyssey and can advice what leds to buy and where to install it etc where to install the keypad in the car where to put the speaker and the siren box etc
but thanks anyway
Old May 30, 2008 | 02:53 PM
B18C_EJ8's Avatar
Ohhh... I understand now...
Buy blue LED's if you're a volunteer fireman (red if you're a chief), green LED's if you're an EMT, yellow if you plow or are a street dept worker, or purple if you're a funeral director.
Since NY State Law prohibits more than one light source, and requires 360 degrees of visibility on any emergency lighting, I recommend installing a bar on the roof.
I would also install the keypad on the dash somewhere.
Siren amplifier would be mounted in the rear cargo area or under a seat or under the dash if space allows.
The siren speaker gets mounted under the bumper cover, preferably pointing forward, also can be mounted dowward, so no water collects inside.
Hope that was helpful.
Old May 30, 2008 | 03:26 PM
cmdm's Avatar
thanks again I intend to have a slimlighter in my windshield, led traffice mover on the upper corner of windshield
led flasher in the back window
maybe flasher in the headlights or the tail lights
I know in the bumper but would love to hear from someone who already installed these things into an odyssey, so I know where to access the firewall, how to remove the bumper or where in the bumper I have space to install the speaker
where do I tap into an ignition on only fuse etc!
Old May 30, 2008 | 05:13 PM
B18C_EJ8's Avatar
http://www.handaaccessories.co...t.pdf
Instructions are for foglight install, but it shows how to get the bumper off...
As far as getting through the firewall, have you even looked under the hood? I can't imagine that there are no grommets that you can push some wires through... Haven't seen a Honda without one...
As far as power sources, there are freepins on the fuse box that you can use for a switched power source.
What siren/light controller are you planning on using?
Old Jun 1, 2008 | 04:05 AM
cmdm's Avatar
I am not sure what controller to use that's part of my question for now on my current Crysler car I have a seperate siren with 2 switches and then 3 switches for my corner lamp strobes..
Now I want 1 controller for them all, and don't think I will install strobes I think I will only go with LED's
Modified by cmdm at 9:15 PM 6/4/2008
Old Jun 1, 2008 | 06:00 AM
B18C_EJ8's Avatar
We just installed a Tomar 940-DCP into a customer's car a couple of weeks ago. Worked very well.
http://www.tomar.com/products/sirens/940.htm
Slim-line control panel hooked up to a main control box mounted in the trunk. The only problem with that unit is that the outputs are low-current, so you can't hook lights directly to it. You need to have the control trigger relays to power lights.
However, we've also had good luck with the TouchMaster Delta... Integrated lights & sirens, but it's quite a bit bigger than I'd like...
http://www.fedsig.com/products/index.php?id=114
Old Jun 1, 2008 | 02:22 PM
cmdm's Avatar
I would not want to ruin my trunk space I would would rather want for all to fit under my seat!
Old Jun 2, 2008 | 05:18 AM
B18C_EJ8's Avatar
Yeah, I know... Because having a six inch square box in your cargo area would totally prevent you from fitting anything else in there...
Old Jun 2, 2008 | 08:44 AM
cmdm's Avatar
LOL but I do use my trunk with seats folded in and carry boxes alot so that small 6" can be in my way .... But I get your point!
can you just tell me which controler works weel with LEDS I same some have a very thin backlit keypad
Old Jun 2, 2008 | 09:48 AM
B18C_EJ8's Avatar
Both of the units I listed will work with LED's.
mikeycivic
Audio / Security / Video
14
Nov 28, 2008 11:53 PM
petwhookie
27
Oct 25, 2008 08:16 PM
sharing@n
Honda Civic (2006 - 2015)
13
Mar 29, 2006 09:29 PM
CzanSOHC
Sep 6, 2002 07:46 PM
