Installing head unit
Old Feb 16, 2003 | 06:09 AM
ilario's Avatar
Default Installing head unit
I just bought a new 2002 Civic LX, is it difficult to install a headunit? I did it before on my 1994 Eclipse.
Old Feb 16, 2003 | 08:48 AM
Skitals's Avatar
Default Re: Installing head unit (ilario)
I have to say this is one of the most retarded threads I have seen. If you have done it before, you should know its not that hard.
Old Feb 16, 2003 | 09:23 AM
clm's Avatar
clm
Default Re: Installing head unit (Skitals)
It depends on the car. Some cars have so much plastic molding around the head unit it's a pain in the *** to do. So IMO, the statement above is not always applicable.
Now, to answer the guys question, it's not that hard on a Civic. I've never done an install on a Civic, but it was a breeze on my Sol. Go to www.installdr.com for a how-to guide on the installation and also try a search in this forum for archived posts.
Old Feb 16, 2003 | 10:02 AM
99_BlackSI's Avatar
Default Re: Installing head unit (clm)
On the newer Civics its not necessarily hard but just contains a lot of work thats all. If you need help on how do it let me know and I will help you out.
Dave
Old Feb 16, 2003 | 12:22 PM
EFsleeper's Avatar
Ok smart ***, how about you put a radio in a 01 GS 400??? ive done it...
Old Feb 16, 2003 | 12:28 PM
EFsleeper's Avatar
step by step-
Remove the piece of plastic that has your cig lighter on it. Its snaps out. be careful
Undo 8mm bolts (2) that are behind the piece of plastic. THese hold the radio in place
Carefully yank the dashpiece containing the HVAC and your radio off the main dash. This can be kind of nerve wracking because they can be tight.
Once its off, unplug the harnesses. Then take it to a workbench
Unscrew the three screws that hold in the HVAC *****, pull the ***** off the front and then unscrew the factory radio. Remove radio/pocket.
Install your aftermarket kit and radio into the dash.
Put everything back together. Its a good idea to keep the metal frame that your factory radio comes bolted to because you can rebolt it in place to steady the dash.
Any more help needed shoot me an IM or email.
Old Feb 22, 2003 | 08:43 AM
ilario's Avatar
Default Re: Installing head unit (EFsleeper)
Where do i buy a kit that will fill the remaining open space where the new unit is?
Old Feb 22, 2003 | 07:50 PM
ilario's Avatar
Old Feb 22, 2003 | 07:51 PM
itsmike's Avatar
local stereo shop.. usually anywhere with stereo stuff for sale.
[Modified by delsolguy1, 8:52 PM 2/22/2003]
Old Feb 23, 2003 | 05:57 AM
ilario's Avatar
Default Re: Installing head unit (delsolguy1)
Does anyplace online sell them?
Old Feb 23, 2003 | 06:22 AM
t0p_sh0tta's Avatar
Cruthfield will sell them, but since your in Shelton, go to the Post Rd. Circuit City, Tweeter, Best Buy, Safe & Sound, Boomer McCloud. One of them has to sell it. No more than 25$
Old Feb 24, 2003 | 10:39 PM
philly-O's Avatar
Default Re: Installing head unit (t0p_sh0tta)
after you take the 2x8mm bolts out, reach up behind the radio and push it out while trying to pull the dash piece off with your other hand.
Old Feb 25, 2003 | 10:51 PM
TurboBumblBee's Avatar
ill completely agree w/ you on that topic.. all cars are different.. the new civics can be a pain in the *** but not hard.. just getting the dash peice out is the hardest part.. we do it a "special" way in my shop.. but it can still be a pain in the *** cause its in there sooo tight..
Old Feb 26, 2003 | 11:34 AM
ilario's Avatar
Default Re: Installing head unit (Hybrid95CivicEX)
Can you explain this "Special way"?
Old Mar 10, 2003 | 03:52 PM
ilario's Avatar
Old Mar 10, 2003 | 04:07 PM
remove the lower console cover, right below the radio.. remove the 2 8mm bolts and then stick a set of plyers, crimpers of somehing that is strong that wont bent.. and push it hard onto the stock pocket.. while your pushing pull on the front of it.. it will come it can be a bitch but honda didnt design it to come out easily..
StealthEK
Honda Civic (2001 - 2005)
Aug 20, 2007 04:02 AM
PatrickGSR94
Audio / Security / Video
12
Aug 30, 2006 08:41 AM
eghatchomar
Sep 13, 2004 07:39 PM
pakiboy949
Aug 16, 2004 09:10 PM
