installing a car alarm....!
Old Jun 24, 2004 | 09:19 AM
phillybeats.com's Avatar
Default installing a car alarm....!
I am installing a new car alarm in my 93 del sol..
as I got ready I noticed that the fuse panel didn’t have that sheet I needed to do so. I want to know is there anyone that has the diagram to share? or know of which wires are which?
I need to locate the ignition wire along with the parking lights . Any help would be great thanks!
Old Jun 24, 2004 | 12:28 PM
sikteg's Avatar
Default Re: installing a car alarm....! (phillybeats.com)
Constant 12V+ White Ignition Switch Harness
Starter Black/White Ignition Switch Harness
Ignition Black/Yellow Ignition Switch Harness
Ignition 2 White/Black Ignition Switch Harness
Accessory Yellow Ignition Switch Harness
Tach Blue Distributor
Neutral Safety Wire Green/White Gear Select Switch under Console
Brake Switch Green/White Brake Switch
Trunk Pin Green/Black (-) Above Fuse Panel Blue Connector
Parking Lights Red/Black Fuse Panel Green Connector
Head Lamp Red/White Light Switch
Hood Pin n/a
Factory Disarm Blue/White
Door Trigger Green/Red (-) Driver's Running Board One of Two Wires
Door Lock Green/White (-) Behind Fuse Panel Gray Connector
Door Unlock Green/Red (-)
Horn Wire Blue/Green (-) Or Gray (-) at Steering Column
Windows Up LF=Blue/Red, RF=Blue/Yellow
Windows Down LF=Blue/White, RF=Blue/Green
Theres your wiring diagram
Old Jun 24, 2004 | 08:41 PM
blueturbo4door's Avatar
Default Re: installing a car alarm....! (sikteg)
you should still always check them with a multimeter
Old Jun 25, 2004 | 06:47 AM
fcm's Avatar
fcm
Old Fart
Default Re: installing a car alarm....! (blueturbo4door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueturbo4door &raquo;</TD></TR><TR><TD CLASS="quote">you should still always check them with a multimeter </TD></TR></TABLE>
also all hondas have a parklight term. on fusebox [ one of the inset flat male spade conn. ]. 94
EFPimpin
Audio / Security / Video
Sep 17, 2010 03:55 AM
4EN[sic]
Mar 9, 2007 05:09 AM
92GSRciv
10
Feb 8, 2007 05:29 AM
AznMTboy
Jun 27, 2005 05:25 PM
