Installation Help
Old Jan 15, 2002 | 02:24 PM
95AccordFL's Avatar
Default Installation Help
Does anybody know the steps to installing a cd player in a 95 Accord LX 2d? If not for that specific car...what do I need to know to install a cd player in general?
Old Jan 15, 2002 | 02:38 PM
95CoupinIt's Avatar
Default Re: Installation Help (95AccordFL)
remove cup holder....extract two screws from underneath...extract screw at an angle that holds entire center console to shifter bezel. ...remove cover plate inside center console....extract two screws there too. remove center console entirely. now extract two screws from black radio/shifter bezel. remove ashtray. now ull see a screw at the top area where the ashtray used to be and take it out. remove black bezel. now remove two 8 mm bolts that hold radio in bezel....unplug harness and remove radio and pocket combo. locate honda wiring harness and wire it up to your new cd player's wiring harness. locate honda multi-kit in order to install stereo. do not lose backstrap adapter that attaches to kit..it holds the stereo in the car. now mount cage in installation kit and install stereo using 2- 8 mm bolts that u just extracted. replace bezel and center console and put screws in to finish the job..should be done in less than an hour if this is ur first time. just remember to make good connections using crimp caps or solder and tape.....do not just use tape..that is freakin ghetto...do it the right way or dont do it at all as i like to say...any questions email me at the address below
Old Jan 15, 2002 | 03:25 PM
95AccordFL's Avatar
Default Re: Installation Help (95CoupinIt)
Thanks man. I'll reply as soon as I get my cd player and tell you how it went. Make sure you stay on this forum in case I totally f up.
Old Jan 15, 2002 | 05:46 PM
95CoupinIt's Avatar
yeah man..this install should be cake for u...even if u've never done this before. lemme know and yes ill be on the forum as always...peace
B.J.
xtreme26
Jul 6, 2007 09:01 PM
xtreme26
Audio / Security / Video
Jul 6, 2007 11:06 AM
Goodbye My Love
Apr 26, 2006 07:29 PM
tangomansi
May 17, 2004 11:26 PM
Fooser
Mar 3, 2002 01:30 PM
