install help
Old Aug 16, 2003 | 11:51 PM
screech's Avatar
Default install help
i have a new pioneer primier 550 to replace my old pioneer i matched up the colors exactly on the harnesses and it wouldnt turn on. then i checked the fuses and connections all seemed ok to me. what else is there that i could be missing.
TIA
Old Aug 17, 2003 | 04:30 AM
t0p_sh0tta's Avatar
Default Re: install help (screech)
There has to be a problem withthe wiring or the fuses. Check again. Try a multimeter (or altleast a testlight) to troubleshoot.
Old Aug 17, 2003 | 07:02 AM
Xsi's Avatar
Xsi
Check the colours didn't change between models, best to go by a wiring diagram
Old Aug 17, 2003 | 07:12 AM
SpeedDreamz.com's Avatar
Default Re: (Xsi)
One difference in the harness is the old Pios 12V battery was orange but the new one is yellow. Also pios have an inline resistor on the red wire in a 1" black housing and the tend to burn very easily. Just cut it out of the loop and reconnect both end of the red. If you dont have a blown fuse, I bet one of these will fix it.
Old Aug 17, 2003 | 12:42 PM
screech's Avatar
Default Re: (30psiCiv)
thnx guys it was under hood fuse sry i checked the inline one and the driver side fuse box inside but really appereciate your help.
fatsalmon15
Audio / Security / Video
Apr 10, 2014 06:44 AM
kirkland08
Jun 17, 2010 09:12 PM
XRacerX
Sep 9, 2009 08:50 AM
superxnova
Feb 22, 2009 02:55 PM
acurciv
Aug 27, 2003 08:53 AM
