Ignition killswitch?
Image is not working.
An ign."kill" switch is not very effective when installed on the ign. lead, too easy to bypass. and the switch would have to be 20-25 amps, [big rocker switch] instead install a small, easily hidden 1amp switch on the ground to the PGM-FI Main Relay, it would kill power to the injectors, fuel pump and other sensors/solenoids and it is on a ground not a power lead. 94
You can wire in a "PGMFI relay" kill switch. Instead of using the power wire, use the ground. It's much safer and you don't have to worry about fusing it. BTW, do not use a lighted rocker switch. It defeats the purpose of "hidden" kill switch.
