how to wire speaker
hey i just took out a 4 channel amp to a mono channel amp for my sub and now i need to know how to wire all my reg speakers back up to the head unit without using the amp....my sn is projectcivicsl on aim if u can tell me there...Thanks
on you head unit you should have 8 speaker wire outputs. if they aren't labeled which speaker is which, get a speaker blown or not just something to make sound. now with sound coming out, change the balance and fade one the head unit to see which one it is. As far as getting the wire to your speakers, you may be able to use the stock wiring. If its not there anymore, its a simple process of running new wire to the doors and wherever else. IS that what you were asking???
basically yea i never really looked on the back of my alpine to see if it had outputs like that...well im a dumbass...hey and on my headunit you can turn the subwoofer bass up how do you wire that up?
RTFM!
Read the Alpine manual... it'll tell you how to wire things up and control the sub section.
If you no longer have the manual, you can find it on the Alpine website. Tell me what model it is and I'll help ya find it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99IntegraGS »</TD></TR><TR><TD CLASS="quote">RTFM!
If you no longer have the manual, you can find it on the Alpine website. Tell me what model it is and I'll help ya find it.</TD></TR></TABLE> Rewiring the speakers will depend on how they were wired in the first place, if the speakers were wired from the amp to the speakers, [direct] then I would pull the speakers and rewire them to the OEM speaker wires, then pull the HU and wire to speaker outputs to the OEM radio harness, and as you have to pull the HU anyway, do that first, and you may se if the speakers were wired the other way, from the amp up to behind the HU to the OEM radio harness, [ then you don't need to pull and rewire the speakers] then just disconnect the wires from the amp to the OEM radio harness and connect the HU speaker wires to the OEM radio harness, at the same time plug one set, [I assume there are 2 sets] of RCAs into the Alpines sub. output RCA, to control the sub, also need to Alpine model # to know if you need to turn sub output on.
PS speaker output color code is........
LF- white, black tracer is neg.
RF- gray "
LR- green "
RR- violet or purple
If a wire adpt. is being used, just match up the colors, but to get the best sound out of the Alpine, [depending on what model] it is best to run the yellow from the Alpine right to the batt., [and cap off the OEM one, white with yellow or blue tracer]
94
RF- gray "
LR- green "
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote">also need to Alpine model # to know if you need to turn sub output on.
AlsoX2... need to know the model to make sure he has a deck with an internal amp. ... ie: NOT a CDA-7998.
</TD></TR></TABLE>AlsoX2... need to know the model to make sure he has a deck with an internal amp. ... ie: NOT a CDA-7998.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectcivicsl »</TD></TR><TR><TD CLASS="quote">the alpine model # is CDA-9827 which is 2004 model</TD></TR></TABLE> It has a 4 x 18watt rms per ch. amp in it, it should be wired to the batt., [the yellow wire] it also has subwoofer pre amp, [RCAs] outputs, you have to make sure that sub is on, when you scroll through your vol, subw, bal, fade, defeat, by pushing repeatedly on "rotary encoader" if SubW does not come on then subwoofer output is not turned on, if you do not have the owners manual, go to http://www.alpine.com click on North America, then Tech Center, then Consumer Site, [lower left] scroll down to Alpine Information Zone and click on Owners Manuals find your unit and down load the manual
94
94
ok ok i have the rear speakers connected and doing the fronts tommorow but now how do i control the subwoofer volume. I have the sub connected to the pre amp out put but idk if there is something i have to do and also im using my old wiring that came from my 2000 model alpine idk if i NEED to use the new one or not
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectcivicsl »</TD></TR><TR><TD CLASS="quote">ok ok i have the rear speakers connected and doing the fronts tommorow but now how do i control the subwoofer volume. I have the sub connected to the pre amp out put but idk if there is something i have to do and also im using my old wiring that came from my 2000 model alpine idk if i NEED to use the new one or not</TD></TR></TABLE>If you are talking about the wire harness that plugs into the back of the HU , "using my old wiring harness that came from my 2000 model Alpine deck" be very carfull, evan though they may look the same and all the wires are the same and it plugs in and the new Alpine works, the yellow memory/amp power wire will not be the same, the newer HU has a bigger amp so it will have a heavier wire and it will be fused higher, also the right plug may have wires on it that the old harness does not, so check.as I said on the post when you push the rotary ****, the one that lets you change from vol. to ball., fade, and defeat, if SubW does not come up the first time you push it, [ ball. does] then you have to turn on the subwoofer output , it tells you how in the manual, if you dont have the manual then go to http://www.alpine.com and download it , you will need it
94
94
aight i got it figured out now but ok i had to rewire my speakers but i cant figure out how the right front speaker runs like i cant see whre it is going or anything but got the others done...HELP PLEASE
Jose-aka-Pedro
Audio / Security / Video
May 15, 2006 11:20 AM
bigfatchien
Oct 25, 2004 10:44 AM
