how should i hook it up?
Old Jan 21, 2007 | 09:01 AM
flatblack-h22's Avatar
Default how should i hook it up?
1x Alpine 9835
1x Rockford Fosgate P312D4 12" 1000W Dual 4-Ohm Subwoofer
1x Q-Logic Single 12" Bandpass Subwoofer Enclosure
1x Memphis Audio MCD500 500x1 Amp(Class D)
how should i hook up the sub with the amp for some good quality? how would you rate these product?
Old Jan 21, 2007 | 09:30 AM
skingfreak's Avatar
Default Re: how should i hook it up? (mr.EGg)
you will want to wire up the sub so that it shows the amp a 2 ohm load.
heres your amps specs if you dont have them http://www.memphiscaraudio.com...L.pdf
and according to crutchfield if you do this you will be running the sub at full RMS power so you should have a good sounding setup http://www.crutchfield.com/S-K...312D4
you may want to look into some bass blockers for your main speakers they sell them at bestbuy and CC for not too much, it takes the load of making bass off of them to make sound better. i did this with my single 12" sub setup and i love it (00 accord coupe)
Edit: here is a link to bass blockers if you decide you need them http://www.crutchfield.com/S-K...g=761
Old Jan 21, 2007 | 09:57 AM
Default Re: how should i hook it up? (skingfreak)
which one of the bass blocker should i get? and what does it mean to wire in parallel?
Old Jan 21, 2007 | 10:11 AM
fcm's Avatar
fcm
Old Fart
Do you mean the R/F P3D412?
http://www.rockfordfosgate.com...tatus=
If so, it is a 500W continuous, [RMS] sub and should work well with the Memphis amp, 1x500W RMS into 4 ohms, however, get rid of the Q-Logic band-pass box, for a few reasons
1- Q-Logic band-pass boxes are crapola
2- With 500W RMS you will blow the box apart, [Q-Logic band-pass boxes are crap]
3- A band-pass box has to be built for the sub going into it, internal volumes of front and rear chambers and port(s) volume(s) have to be exact, and with a generic band-pass box they will not be.
4- You will damage the box, the sub and possibly the amp, you can not hear a clipping amp when sub is in a band-pass box.
5- Did I mention the Q-Logic band-pass boxes are crapola?
If you want good SQ from you sub, find the recommended 1 cuft sealed box... http://www.rockfordfosgate.com...94234
You will be a lot happier. 94
Old Jan 21, 2007 | 10:29 AM
skingfreak's Avatar
you wire them up in line of the postive wire for each speaker.
++++bass blocker+++
wire them up like that ^^^
and as for which one it depends on where you want your cut off points to be.
Old Jan 21, 2007 | 11:08 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skingfreak &raquo;</TD></TR><TR><TD CLASS="quote">you will want to wire up the sub so that it shows the amp a 2 ohm load.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Do you mean the R/F P3D412?
You will be a lot happier. 94</TD></TR></TABLE>
it says P312D4 on the sub and the box itself. i bought the system use so it came with that box..
AMP
|_____| = 2 OHM Load
SUB
|______|
|___|
+ - &lt; AMP
is that right?
Old Jan 21, 2007 | 11:29 AM
skingfreak's Avatar
here is a link to wiring up subs http://www.crutchfieldadvisor.....html
now here is the link that will really help you http://www.crutchfieldadvisor....VC4x2
but that is genrally how you wire up your amp to be bridged.
Old Jan 21, 2007 | 02:53 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skingfreak &raquo;</TD></TR><TR><TD CLASS="quote">but that is genrally how you wire up your amp to be bridged.</TD></TR></TABLE>Maybe you will want to edit that part? 94
Old Jan 21, 2007 | 06:43 PM
skingfreak's Avatar
Default Re: how should i hook it up? (fcm)
did i say something wrong. i wasn't refering the sub when said that, i was talking about his previous question about the amp wiring up. even tho most of my last post had to do with sub wiring. is that what you were talking about?
Old Jan 22, 2007 | 07:33 AM
fcm's Avatar
fcm
Old Fart
It's a mono-block amp, no bridging required. 94
Old Jan 22, 2007 | 10:57 AM
8520's Avatar
The cda9835 has built in crossovers iirc, and as such bass blockers are not needed
Old Jan 22, 2007 | 03:08 PM
skingfreak's Avatar
now that i re-read his orignal post i see that its a mono block lol. when i replyed i simply looked at his diagram that he drew and thought it was a two chanel. here is a perfect time for the HT hamer.
VietFoo
Audio / Security / Video
Oct 21, 2005 11:52 AM
89hbcivicguy
Mar 3, 2005 09:12 AM
CivHatchH22
Apr 12, 2004 09:21 AM
02AccordCoupe
Dec 5, 2001 10:31 AM
LuDeS
Nov 3, 2001 03:43 PM
