how much should a box cost?
Old Apr 19, 2001 | 07:33 PM
RevedOut's Avatar
Default how much should a box cost?
i was wondering if you guys can tell me how much should i be paying for one 12" band pass box and how much installation of a box and amp should be to a stock integra. thanks
Old Apr 20, 2001 | 07:41 AM
cartelcivic's Avatar
New User
Default Re: how much should a box cost? (RevedOut)
A dual or single 12" bandpass box???, the dual 12 is about $$150 and the 10" i have to check, (install) depending on where you go will be different!! if you happen to go to Best Buy the it would be about $50 plus the wires, comes out to a usaual $120-$130...
Dave
Old Apr 20, 2001 | 07:33 PM
RevedOut's Avatar
Default Re: how much should a box cost? (cartelcivic)
single?
Old Apr 23, 2001 | 12:07 PM
bruthaboost's Avatar
If you are trying to save money, have a circular saw and moderately industrious, you could build your own. You would need a box building program and the specs of your speaker. There are plenty of programs out there. Home Depot has the MDF or particle board, glue, and screws. Walmart, Target, Mailbox etc, has the cardboard mailing tubes in whatever diameter and length you need. You could use PVC, but cardboard is way easier. Plus you get the satisfaction of having a box built to fit your trunk!
Old Apr 23, 2001 | 06:37 PM
TeG cRaZy's Avatar
Default Re: how much should a box cost? (b18bpwr)
what are the programs called?
Old Apr 24, 2001 | 06:48 PM
Default Re: how much should a box cost? (TeG cRaZy)
Here's a link to a down load site with a box building program. There are more outthere. Just use any search engine. I would down load a few and compare the results they give you.
http://www.zdnet.com/downloads/stori...,,000N64,.html
Oh yeah forgot to mention. Home Depot also has the plexiglass you'll need if you DIY. Lots of luck to ya!
[Modified by b18bpwr, 7:50 PM 4/24/2001]
mitsuman
Audio / Security / Video
13
Dec 2, 2007 03:37 PM
95CivicDude
Mar 19, 2003 10:11 AM
redteg1
May 16, 2002 05:33 PM
Cryptopsy
Feb 16, 2002 09:24 AM
mickey513
Nov 17, 2001 06:27 PM
