how many ohms is this...DVC?
Old Apr 19, 2003 | 11:23 PM
cd5_2NR's Avatar
Default how many ohms is this...DVC?
i got some extra 12's laying around..they're the latest KENWOOD excelon DB+...they're DVC..so both are 4ohms right now..im wiring them...uhh..i dont know what its called...series or parallel, but all positives together and all negatives together....so thats 8ohms...regular...what does it drop to...do they both drop to 2ohms then combine that and it becomes 4ohms all together..>?????sorry i get mixed up with that DVC+ohm ****...???
Old Apr 20, 2003 | 12:26 AM
vteg's Avatar
New User
Default Re: how many ohms is this...DVC? (zeROTWO_CG6)
I am confused. What is the rating per coil? If you have 4 ohm vc's and they are wired together in parallel(+ to + and - to -) then you have 2 ohms per speaker. From here you can have 1 or 4 ohms if you connect the two subs together.
Old Apr 20, 2003 | 05:09 AM
Xsi's Avatar
Xsi
Have a look on here: http://www.jbl.com/car/Subwoof...m.asp
Old Apr 20, 2003 | 09:45 PM
cd5_2NR's Avatar
Default Re: how many ohms is this...DVC? (vteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteg &raquo;</TD></TR><TR><TD CLASS="quote">I am confused. What is the rating per coil? If you have 4 ohm vc's and they are wired together in parallel(+ to + and - to -) then you have 2 ohms per speaker. From here you can have 1 or 4 ohms if you connect the two subs together.</TD></TR></TABLE>
okay..i remember now...thats it..you're right..it does down to 2ohms...
what happens if i run a 4ohm stable amp to it...??? bad/good...
Old Apr 20, 2003 | 10:49 PM
vteg's Avatar
New User
Bad.
Old Apr 20, 2003 | 11:06 PM
cd5_2NR's Avatar
wait a minute...you said its either a 1ohm or 4ohms all together right...so the two wired parallel brings them in total to 4ohms???? am i right or is it still 2ohms...
Old Apr 20, 2003 | 11:22 PM
vteg's Avatar
New User
If the speakers are wired to 2 ohms, you can get 1 or 4 from the pair. If you wire the pair to a 4 ohm total load then you are golden.
PS, connecting the two subs should be series not parrallel. It may be safer for you to wire the subs vc's in series, giving you 8 ohms per sub, and then parallel to bring the pair to 4. Less chance of smoking your amp that way.
Old Apr 21, 2003 | 12:42 PM
cd5_2NR's Avatar
okay...one last question, so they shoud be wired series not parallel? and what must i do to get them to be at 4ohms combined????
Old Apr 21, 2003 | 01:02 PM
cd5_2NR's Avatar
okay i saw this...and it looks like right to me but just need other info...it shows wiring for 2 DVC 4ohm subs...and says its 2 4ohm subs = 4ohms...and its wired like this...should i try this instead...???
Old Apr 21, 2003 | 01:28 PM
cd5_2NR's Avatar
okay..i finally got more info...
series will make my load 4ohms...
parallel will make it 1...
i have a kenwood 729s 300x1...which load should i go with...right now i have it wired at 1ohm and was told it draws too much power and could cause a lot of overheating on the amp but is probably gonna be louder than series, would series sound more clear?...any other suggestions..????
Old Apr 21, 2003 | 03:39 PM
cd5_2NR's Avatar
nevermind..i tried both and it sounds a lot louder and more bass wired parallel...
lickety_britches
Audio / Security / Video
Dec 18, 2007 02:46 PM
1SlowSi
May 23, 2007 05:13 AM
Buck99Si
Apr 26, 2005 01:20 PM
initialvtec
29
Jun 17, 2004 01:22 PM
EGPrelude
Feb 16, 2004 10:27 AM
