How important is THD when dealing with subs?
Old May 18, 2004 | 05:03 PM
technine's Avatar
Default How important is THD when dealing with subs?
I know THD is all about how clean the sound is amplified, but how important is that with subs? The only sound that will be coming out will be low pitched sounds and I assume that a higher THD is not going to effect it as much as if I were to power my mids and tweets.
What would be the maximum THD for clean sounding bass? TIA
Old May 18, 2004 | 08:33 PM
vteg's Avatar
New User
Default Re: How important is THD when dealing with subs? (technine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by technine &raquo;</TD></TR><TR><TD CLASS="quote">
What would be the maximum THD for clean sounding bass? TIA</TD></TR></TABLE>
10% is what is considered acceptable.
Old May 18, 2004 | 11:11 PM
technine's Avatar
Default Re: How important is THD when dealing with subs? (vteg)
So anything under 10% will sound clean? I see the real cheap amps have a THD of .05% and the really good ones have like .002%. So I guess I just have to consentrait on the RMS of the amp @ what OHMs to pair up with the speaker then.
Thanks.
Old May 19, 2004 | 05:18 AM
nsxxtreme's Avatar
What is more importnant is what the actual power output is. Amplifier companies find interesting ways to rate there amps. Not all amps are created equall. Pay attention to what frequency the RMS reading is rated at it should only be from 5-20kHz.
Old May 19, 2004 | 07:27 AM
hoggy's Avatar
Car audio companies are pretty shady as far as ratings go. You can't judge an car audio equipment by its specs hardly anymore. You have to take it for what its worth. Learn the equipment from experienced users or listen to the equipment yourself in car audio shops.
Old May 19, 2004 | 11:17 AM
technine's Avatar
Default Re: (hoggy)
Thanks guys, this really helped a lot. I need to go out and take a listen and tell the difference for myself or go with a good quality product that has good reviews. Thanks again for the info peoples.
Old May 19, 2004 | 04:15 PM
ShaunRR's Avatar
HT White Ops
Community Builder
It is not much of an issue with subs. That is why class D amps are meant for subs.
If you are trying to use this to judge quality, just keep in mind that in car audio you get what you pay for.
Mentat Ghola
Audio / Security / Video
Jul 2, 2009 10:46 PM
imadigitalgod
Oct 2, 2007 08:02 AM
Sinner
Feb 14, 2006 07:27 PM
miksew
May 1, 2004 07:40 AM
Jan 21, 2002 08:43 PM
