How the heck does this work?
Old Jun 29, 2015 | 06:26 PM
ALDJ253's Avatar
Default How the heck does this work?
I am wanting to add subs to my Factory radio in my 2004 Acura TSX. I cannot add a new HU with RCA Outputs (Like I am used to) because of the Navi. I have been looking around and have seen that people just use an LOC in their trunk and have it attached to their 6x9s
So for me to do this, I would buy a 2 channel LOC and connect them to the 6x9 speakers. However, I am lost on how the heck my 6x9s will be getting signal if I cut the wire and use it on the LCA. Do I go ahead and use something such as a T-splicer for all 4 wires?
Old Jun 30, 2015 | 03:02 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: How the heck does this work?
You don't cut the stock speaker wires to the 6x9s. You strip the insulation of the wires and tap onto them. Solder instead of using that t-splice crap and cover with black electrical tape. I would suggest getting an AudioControl LC2i instead of those cheaper LOCs out there.
Old Jun 30, 2015 | 05:31 AM
MotoCARR's Avatar
PAC Audio
Pac-Audio.com Product Details | iPod Integration for your car and More by Pac-Audio - Connecting you to the future
Scosche
Lineout Convertor Adjustable 80 Watt | loc80 | Car Line Out Converter | Lineout Convertor-adjustable 80 watt | by Scosche
Car Stereo Output Converter | Speaker Connectors | Car Audio Systems | Car Stereo Output Converter | by Scosche
Metra
Metra Online
Metra Online
Metra Online
Metra Online
All will do what you are looking for.
Old Jul 4, 2015 | 08:53 AM
ALDJ253's Avatar
I realized that my Kenwood KAC8105D has Speaker Level Inputs. However, since I purchased this amp used, it did not come with the connector. The connection appears to be a 10-pin connector, however, I cannot find one.
Here is a link to the pic of the amp
https://www.google.com/search?q=Kenw...Pv3VANVeckM%3A
Here is a link to the pic of what I believe to be the connector, of which I cannot find
https://www.google.com/search?q=10+p...ZB7j539whFM%3A
Old Jul 6, 2015 | 05:23 AM
MotoCARR's Avatar
Going to look something like this
Contact these guys, maybe they can hook you up with the right one.
Kenwood Accessory Store
Also, I would HIGHLY recommend that you put something like the PAC LC-1 along the RCAs. It will give you a lot more flexibility in controlling the bass level, besides adjusting it on the radio. That way you don't have to sacrifice the sound of the interiors by having to set the bass on the radio all the way down.
PAC LC-1 (lc1) Universal Remote Level Control via RCA Audio
Old Jul 6, 2015 | 12:01 PM
ALDJ253's Avatar
So if I do go the route of the LOC, then get the Pac LC-1?
Thanks I shall try contacting them
Old Jul 8, 2015 | 05:10 AM
MotoCARR's Avatar
Even if you don't use a LOC I would use an LC-1 lol. I suggest it anytime subs are run off an OEM or a radio that does not have independent sub volume control. Lowering the bass setting on the radio is not the solution, it does make a difference.
Old Jul 9, 2015 | 08:51 PM
mechanix619's Avatar
Contact Mercman. He's on various Honda/Acura forums. He might be able to help.
He built me a custom harness that bypasses the stock amplifier on a 9th Gen Civic Si.
Old Jul 9, 2015 | 08:57 PM
Example from Acura Zine
http://cimg9.ibsrv.net/gimg/acurazin...9c9c186b25.jpg
Old Jul 13, 2015 | 04:52 PM
ALDJ253's Avatar
Originally Posted by mechanix619
How do I go about finding him?
Edit: Found him
Old Jul 15, 2015 | 04:13 PM
Edit: Found him
Any luck?
Old Jul 16, 2015 | 12:03 PM
ALDJ253's Avatar
Any luck?
He sent me this
"Just get an amp with speaker level inputs and connect it to the rear 6x9s. You can get the speaker wire adapters (Honda 98 and up) so you don't have the cut any wires. If you plan to go with an amp for the main channels than get one with balanced inputs so you can go direct to the HU with my harness.
Jeff "
Old Jul 16, 2015 | 12:39 PM
He sent me this
Jeff "
Is your goal to just add a sub or sub plus front speakers?
Old Jul 17, 2015 | 05:24 PM
ALDJ253's Avatar
Just a dual 12 inch subs
janek
Apr 8, 2013 03:37 PM
lee0149
Audio / Security / Video
13
Jan 7, 2009 08:47 PM
dafuzzbudd
18
Nov 30, 2006 09:15 AM
92civicsi
Apr 12, 2003 09:20 PM
slammmedintegra
Nov 27, 2002 02:11 PM
