how to get power thru the firewall
Old Apr 20, 2004 | 10:11 AM
newbie_on_the_doobie's Avatar
Default how to get power thru the firewall
hi i was wondering if anyone knew where abouts i could get the power thru the firewall on a new civic without drillong a hole?
Old Apr 20, 2004 | 10:29 AM
92BlackSi's Avatar
Default Re: how to get power thru the firewall (newbie_on_the_doobie)
look at where the main wiring harness enters the cabin on the firewall. You should be able to pull that grommet back and run your wire through, although you may need to slightly enlarge the grommet hole to accomodate a power wire. That is what I did.
Old Apr 20, 2004 | 10:36 AM
Default Re: how to get power thru the firewall (92BlackSi)
thanx ill try it
Old Apr 20, 2004 | 07:08 PM
From: eating the shit out of pizza in raleigh, NC, USA
it you remove your battery there is a gromet (dont know if i spelled that right...) behind/underneath it... its kinda hard to get to b/c you have to move lots of ****, but its the best to use cuz it looks the cleanest.
Old Apr 21, 2004 | 10:45 AM
greebler's Avatar
Default Re: how to get power thru the firewall (2ndchancehonda)
Use a coat hanger and jam that though first and duck tape the cable to it and yank it through; there is a hole behind the glove box in pretty much all hondas\acuras that I have worked on. You may have to take out hte battery to get to it....
themiller13
Jan 21, 2020 05:43 PM
Mashi2Choco
Apr 21, 2008 11:29 AM
Kangolbrand
Audio / Security / Video
May 23, 2007 01:05 AM
b16_madman
Nov 4, 2005 07:14 PM
jonoknut
Sep 19, 2002 03:17 PM
