How to get parkinglights to come on with keyless entry?
Old Nov 29, 2002 | 07:15 PM
FourthGenHatch's Avatar
Default How to get parkinglights to come on with keyless entry?
While I'm doing this I figured I would asked. My Autoloc told me to hook it up one way and I did it right but the keyless doesn't work with the wires hooked up. It told me to the following...
87 - Wire into the parkinglight wire
86 - 12+ constant
30 - wire it into 86
85 - a yellow wire from the reciever
When ever that yellow wire is plugged into the relay my locks don't work at all, if I pull it out they magically work again. So any ideas of how this should go. I did just what Autoloc said and it didn't work so now I'm asking you guys.
Old Nov 29, 2002 | 07:37 PM
Desslok's Avatar
Default Re: How to get parkinglights to come on with keyless entry? (FourthGenHatch)
try this, remove 30 and 87 and see if your locks stop working. You might have a bad relay.
Old Nov 29, 2002 | 08:03 PM
Default Re: How to get parkinglights to come on with keyless entry? (sp)
I tried 2 different relays. Same thing happened.
Old Nov 29, 2002 | 08:05 PM
I think they all might be +. The yellow wire is what I touch to a 12+ to program the remotes so do you think I need a ground on one of them?
ekillah
Audio / Security / Video
Apr 17, 2009 05:37 PM
14bcoupe
Welding / Fabrication
12
Apr 19, 2005 11:20 AM
buzzsawstan
Jun 30, 2004 09:09 PM
ScottEK
Jul 23, 2003 10:06 AM
OldSchoolHatch
Jul 12, 2003 09:55 PM
