how to fix
Old Oct 2, 2005 | 08:44 AM
deeweezy187's Avatar
Default how to fix
Does anybody know how to fix a bad turn on led.
Old Oct 2, 2005 | 09:09 AM
fcm's Avatar
fcm
Old Fart
Default Re: how to fix (deeweezy187)
All you can do is replace it, you can't fix an LED. 94
Old Oct 3, 2005 | 04:58 AM
B18C_EJ8's Avatar
Turn on LED? Like the power light on your amp?
Or turn on leAd? Like the blue or blue/white wire coming off the deck that turns your amp on and off?
Old Oct 4, 2005 | 04:31 AM
Default Re: (B18C_EJ8)
i have a problem with my system i made a turn to hard to avoid something and next thing i know my subs and amp cut off and it won't cut back on and i changed the ground wire and i dont know whats wrong and somebody told me a bad turn on led. Maybe you can help me from that.
Old Oct 4, 2005 | 05:51 AM
B18C_EJ8's Avatar
Check your main fuse on the power wire from the battery. Check the fuse(s) in the amp. Check to see if you've got voltage at the "Rem" or "Remote" terminal on your amp.
Old Oct 4, 2005 | 07:26 AM
nsxxtreme's Avatar
If your amp wont turn on I highly doubt a burned out LED is your cause. I am about 99.5% sure of that. Without looking at the amp circuit I can't be 100% sure. Start looking elsewhere as already mentioned above.
Old Oct 4, 2005 | 07:49 AM
B18C_EJ8's Avatar
I just think he's misspelling the word 'lead'...
If the turn on lead (wire) from the deck is indeed bad, it's a relatively easy fix to get your tunes back... Just wire the remote terminal on the amp to a source of switched power... Free pin on fuse box, red wire on radio, etc...
NewtoCivics
Audio / Security / Video
12
Jan 11, 2012 04:28 AM
ip428
Aug 1, 2008 03:45 PM
PnoyJeff
11
Feb 18, 2006 11:32 AM
deeweezy187
Jun 19, 2005 09:01 PM
allmotorEG-SI
18
Apr 9, 2005 10:26 AM
