HOW DO I INSTALL AND AMP
Old Feb 15, 2005 | 05:46 PM
blackhondasc1998's Avatar
Default HOW DO I INSTALL AND AMP
HOW DO I INSTALL AND AMP IN A HONDA DO U RUN IT TO THE BATTERY OR DO U NEED TO DO SOMETHING ESLE
Old Feb 15, 2005 | 06:13 PM
CooBlueDAB's Avatar
Default Re: HOW DO I INSTALL AND AMP (blackhondasc1998)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackhondasc1998 &raquo;</TD></TR><TR><TD CLASS="quote">HOW DO I INSTALL AND AMP IN A HONDA DO U RUN IT TO THE BATTERY OR DO U NEED TO DO SOMETHING ESLE</TD></TR></TABLE>
lose the caps... it makes people get sickened by you.
Edit: Also searching will get you all the information below, once you get specific questions from that, come back with info on what you are installing exactly.
After that, I am going to guess you have no idea on installing an amp at all.... so here is some basic info, I'm sick so I dont have much time.
Battery to trunk is best, there is a grommet below the bat and to the right, I have a write up on this for a coupe, but it works for any really...
Run the RCAs separate from the power cables, many people will say to do it down the center of the car, I did mine on separate sides. power down passenger under plastic, and RCA down driver, they will say there are many power wires and harnesses on the drivers side, they are right, but I have not noticed any interfeerence from them. I wanted to save cost by keeping power cable footage low.
Old Feb 17, 2005 | 08:15 PM
92integra13's Avatar
ok this seems like its your first time so you will probably have some trouble with this but ill give it a shot anyway. First i hope you have the amp, and depending on how big you amp is going to determain what sort of amp kit you need. You will end up with a 8 gauge or a 4 gauge amp kit most likely but if you dont know which one to get bring the amp with you and they will know what gauge you need. Make sure it has the fuse block with it so if your wiring is wrong you wont burn up your car. Run the power wire from your battery, through your firewall and back to your trunk, the rca's and the remote wire from the radio to your trunk, and bolt your ground wire some were on the fram of your trunk, but not on any metal or you wont get a good connection. Then hook the wires up to the amp and thier you go. Good luck
riceball777
Honda Civic (2006 - 2015)
Dec 19, 2013 02:57 PM
rahfiki
Audio / Security / Video
Mar 9, 2009 08:50 AM
carloselpavo
11
Sep 26, 2007 06:46 PM
mmajedi
Aug 17, 2007 08:39 AM
skier4life0315
Jul 28, 2006 03:10 PM
