how do i hook up rear speakers?! please help!!!!!
i have 6.5 inch 3 way speakers in the front. what else will i need to put in my 3 way six by nines if my car only came with the 2 front speakers? Will i need to get a crossover? or can i just wire them to the fronts? thanks Garrett
OK, I don't whether or not you will be able to get 6 x9's into the back but I know 6.5" round ones will fit.
In the back of your car on each side you will see a small panel in the main side panel of the car. First you must pop this panel out. (lower your seat and pry with a flat head screwdriver at the back of it, it should come out easy.) This will give you access to everything behind the side panel. Reach down into the very bottom and see if you can pull up a wire, you might be able to, and you might not. DON'T FORCE IT!!! if you can't get to it don't worry, that would have been your speaker wire already run. If not you can run it your self.
Anyway, cut the appropriate size hole into the side panel you removed and fit your speaker.
Wiring. If you couldn't get the speaker wire that was already there you will need to run your own. Start at the deck, figure out which wires on the back of your deck are for rear speakers and run a wire from that, down each side of the car(pop up the plastic thing that goes along the door and run the wires under the carpet on each side.) from there you should be able to run them up into the area where you were working before. Pull them up and out the panel hole. Connect each side to each speaker, replace the panel and your done.
I WILL NEVER EVER EVER TYPE A MESSAGE THIS LONG AGAIN.
CivicSi95
Audio / Security / Video
Feb 10, 2009 08:43 AM
xXx Justin xXx
18
Mar 21, 2003 03:01 PM
