how to change sensitivity on viper?
Old Apr 7, 2003 | 08:50 PM
chris408's Avatar
Default how to change sensitivity on viper?
i have a viper 550 esp. i was wondering how can i change the sensitivity. im paranoid aboutmy car. for my alarm to turn off you have to bang it hard. but i want it where if you touch it itll chirp. thanks
Old Apr 7, 2003 | 11:13 PM
chris408's Avatar
Default Re: how to change sensitivity on viper? (chris408)
ttt
Old Apr 7, 2003 | 11:29 PM
OC 335i's Avatar
On the brain, there is a flat plastic screw you can turn...
Old Apr 7, 2003 | 11:43 PM
chris408's Avatar
Default Re: how to change sensitivity on viper? (MEGA EK)
where can i find the brain..i didnt install it so yeah
Old Apr 7, 2003 | 11:52 PM
OC 335i's Avatar
Ask the person who installed it.
The brain is generally installed underneath the dash if it was just a generic install. Do you have an alarm LED? If you do, follow that wire... It should lead to the brain.
Old Apr 8, 2003 | 06:08 PM
CustomCJ00's Avatar
you need to find the shock sensor
the viper units are a clear plastic square about 2 inches square
it has a orange adjustment screw on one side
you will need a small flat head screwdriver to adjust it
usually it is mounted to the stearing column or to the alarm harness itself
if u are having trouble finding it try sticking your head under the dash and hitting your stearing wheel. the shock sensor will light up red when it sences the impact.
Old Apr 8, 2003 | 09:10 PM
chris408's Avatar
Default Re: how to change sensitivity on viper? (CustomCJ00)
thanks guys!
Old Apr 8, 2003 | 10:58 PM
TurboBumblBee's Avatar
yea listen to him.. he is correct..
rancidhooligan
Audio / Security / Video
Nov 14, 2007 05:02 AM
Jap_Spec_Imports
Jun 22, 2006 04:36 PM
k7q
Mar 6, 2006 01:57 AM
92LudeSI
13
Mar 17, 2005 04:47 PM
d8168055
Jun 15, 2002 09:15 PM
