high/low converters...
Old Oct 1, 2002 | 01:33 PM
sleeperaccordv6's Avatar
From: west Ft.Worth, Texas, the big one in the center
Default high/low converters...
does any one use one? I want to keep my stock indash changer and wire a sub amp, and I was wondering what brands are better,ect..any personal imput would be appreciated..thx
Old Oct 1, 2002 | 06:09 PM
philly-O's Avatar
Default Re: high/low converters... (sleeperaccordv6)
at work we use the peripheral brand
Old Oct 1, 2002 | 06:39 PM
TurboBumblBee's Avatar
Default Re: high/low converters... (peichie)
we use the same ones at circuit city
Old Oct 1, 2002 | 10:21 PM
audioroach's Avatar
Default Re: high/low converters... (95CivicEX)
So do us Tweeter guys.....Pac,audio link,xtant any good brand name...avoid the ones with a power line in them...you are just asking for trouble.....so i guess you have the answer.
I had a thought...has anyone taken or made rca's ( yes it can be done) and connected speaper output directly to them and feed this into the amp...I see what im gonna be doing this weekend.
Old Oct 2, 2002 | 09:38 AM
smdandb2's Avatar
Default Re: high/low converters... (audioroach)
You're gonna clip the amp and possibly fry the circuitry doing that.
I have a 10band MTX EQ that has high and low level inputs. So thats what I used with my stock deck. Plugs into a Fosgate Punch 200ix, and a PPI Flat Piston 10. Sounds alright, I need a new deck though. Stock just isnt cuttin it!
Old Oct 2, 2002 | 06:13 PM
philly-O's Avatar
Default Re: high/low converters... (smdandb2)
xtant actually claims that thier inputs are so strong and that they amplify the signal enough that they say you can do that (x series amps only). it actually works....well
Old Oct 2, 2002 | 07:40 PM
audioroach's Avatar
yes they are...that where it got the idea from...and i was thinking since most amps can handle a 2volt avg input ( and im not some yahoo who wants to do this)..I planned on doing a little expriment this weekend...this should be fun.
Disclaimer:the following actions are being performed by a trained professional with many years of experience and a grasp of the inner workings of 12 volt electronics....In no way is this an endorsement of either Honda-Tech or its moderators...Proceed at your own risk...close before striking...look both ways..dont try this at home...Yada yada yada.....
In other words:If you **** up ya ****...you is a DumbAzz and you have been warned.
We now return you to the regular programming now in progress.....
Old Oct 2, 2002 | 07:59 PM
nsxxtreme's Avatar
most of the line level converters I know of use a step transformer in them. You could try to use resistors to build a voltage divider. I think this is what the cheaper convertors use.
Old Oct 3, 2002 | 08:49 AM
Resurgent's Avatar
Just buy a amp with good high level inputs - damn coverters suck ! say hello to MR. Ground Loup
Walterronny
Welding / Fabrication
Oct 9, 2011 03:31 PM
dopey88
Apr 23, 2007 08:58 PM
2000vsm
Aug 25, 2003 06:44 PM
