high level input vs. rca input
Old Apr 29, 2003 | 11:33 PM
SSBP DC2's Avatar
Default high level input vs. rca input
what is the difference between high-level input and low level (rca) inputs? i'm hooking up an amp to power my speakers and i wonder if i need to run and buy 2 sets of rca for this 4 channel amp of mine or could i just use the high level input instead? i'm not cheap as those rca's are probably only $20 but just wondering what is the difference in them. TIA -td
Old Apr 29, 2003 | 11:47 PM
vteg's Avatar
New User
Default Re: high level input vs. rca input (SSBP DC2)
High level = speaker outputs
Low level = cleaner signal for an amp
Use low level if possible.
Old Apr 30, 2003 | 12:07 AM
SSBP DC2's Avatar
Default Re: high level input vs. rca input (vteg)
thanks. so using the high level output will only create more distortion in signal hence should be stayed away from?
Old Apr 30, 2003 | 12:39 AM
vteg's Avatar
New User
Yep.
Old Apr 30, 2003 | 01:36 AM
99turbosi's Avatar
Just a TIP:
Try to keep them at least 18" from an power source in the vehicle, best to run the power and remote wire down one side & all signal wires down the opposite so as to eliminate the chance of inductive coupling.
Old Apr 30, 2003 | 12:29 PM
SSBP DC2's Avatar
thanks
8YourV8
Audio / Security / Video
13
Dec 11, 2010 09:50 AM
oilguzzler
Apr 13, 2006 12:17 PM
91DroppedHatch
Jun 20, 2005 02:57 PM
Ricey McRicerton
Jan 22, 2004 12:58 PM
loki2323
14
Nov 19, 2002 08:14 PM
