HID retrofit question
Old Mar 7, 2006 | 06:46 PM
texan_176's Avatar
Default HID retrofit question
I did a search and found a few threads that offered great info. on this. However, I did not find a conclusive answer to something that is very unclear to be about this mod. I will be retrofitting S2000 projectors with factory D2S bulbs.
Do you suggest I use the Honda ballast even though it is very expensive used or can another one be used and perfomr just as well?
Also, do all ballasts that fire D2S bulbs use the same type of INPUT connector to draw power from the battery?
I need to buy a Harness and don't know which one to buy because the manufacturers do not clearly explain which ballast (name brand) the 9006 harness will plug into.
I found a guy selling complete S2000 projectors with the bulbs and ballasts for $450. This is a great price and if I can use all of the Honda stuff I will do this mod.
Please provide links to reputable vendors of a harness with your 2 cents in this.
I didn't see a lighting section in the tech. topics so I posted here; moderator please move my post if need be to the correct place.
Thanks!
Old Mar 7, 2006 | 08:00 PM
B18C_EJ8's Avatar
http://www.hidplanet.com FTW...
99em1_sir
28
Jan 27, 2007 01:12 PM
EG_R
Jan 5, 2007 11:37 AM
initialR
May 3, 2006 01:55 PM
MikeTV
Jan 28, 2005 09:00 AM
JDM1civic
Sep 15, 2004 01:37 PM
