help with wiring..
Old May 4, 2006 | 05:39 PM
Fliplm0de's Avatar
Default help with wiring..
i need help wiring these fogs on.. it says "Attatch the ground terminals of (black) ground extension wires to any metal ground under bumper using small sheet metal screws."
does this mean i drill a hole in the radiator support or something and screw it down??
it looks like this
http://i22.photobucket.com/alb...9.jpg
sorry this is my first time dealing with electric work.
Old May 4, 2006 | 06:15 PM
Kavehman's Avatar
Default Re: help with wiring.. (Fliplm0de)
you don't need to drill any holes, just find an existinf screw, that is screwed into metal, unscrew it, strip off any paint around the screw and attach your ground to that point.
If you dont wanna do that you could attach it directly to tge stock grounds on the car, just look for cable going from the motor to the frame of the car
Old May 4, 2006 | 06:44 PM
fcm's Avatar
fcm
Old Fart
You should not have to drill a hole, [unless the ground leads are too short] if you look you will find all sorts of bolts and screws going into the rad support and around it some of them may even be ground leads for other things, use one of them. 94
Old May 4, 2006 | 07:31 PM
Fliplm0de's Avatar
Default Re: help with wiring.. (fcm)
thanks.
92 CiviC H.B
Apr 24, 2009 06:49 PM
shivern
Jan 4, 2005 07:33 PM
bman2033
May 10, 2004 09:38 PM
bman2033
May 6, 2004 09:19 PM
BlendedEJ8
Apr 25, 2003 06:40 AM
