HELP! VIPER 550 ESP lighting issue
Old Oct 24, 2004 | 12:46 PM
Going Postal's Avatar
Default HELP! VIPER 550 ESP lighting issue
well heres the problem...i bought my car with a viper alarm 550esp. everything works fine except whenever i arm/disarm the car the parking lights dont flash. i checked the wires and found the white wire unplugged.. which is supposed to be connected to the parking lights? http://directechs.com/guides/m...V.pdf
so where do i connect it to??? im not very good with alarms
Old Oct 24, 2004 | 04:13 PM
D'Ecosse's Avatar
Default Re: HELP! VIPER 550 ESP lighting issue (SoLOW916)
It shows you how to connect it right on the bottom of page 9 or top of page 10, depending on what car you have - can you identify your car model & I'm sure someone can tell you exactly ideal location & colour wire to splice that wire to.
Old Oct 24, 2004 | 04:30 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoLOW916 &raquo;</TD></TR><TR><TD CLASS="quote">well heres the problem...i bought my car with a viper alarm 550esp. everything works fine except whenever i arm/disarm the car the parking lights dont flash. i checked the wires and found the white wire unplugged.. which is supposed to be connected to the parking lights? http://directechs.com/guides/m...V.pdf
</TD></TR></TABLE>If your car is a Honda/Acura there is a parklight freepin on the fuse box. 94
Old Oct 24, 2004 | 04:46 PM
Default Re: HELP! VIPER 550 ESP lighting issue (fcm)
i have a 97 civic hatchback, ive tryed all the free pins on my fuse box andd the black/red wire in my kick panel, but i will try it again tomorrow.
Old Oct 24, 2004 | 04:58 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoLOW916 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 97 civic hatchback, ive tryed all the free pins on my fuse box andd the black/red wire in my kick panel, but i will try it again tomorrow.</TD></TR></TABLE>Have you checked the fuse on the white parklight output wire from the alarm? 94
Old Oct 24, 2004 | 09:43 PM
i dont recall seeing a fuse connected to the white wire, but ill check that.
Old Oct 24, 2004 | 10:52 PM
D'Ecosse's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoLOW916 &raquo;</TD></TR><TR><TD CLASS="quote">i dont recall seeing a fuse connected to the white wire, but ill check that.</TD></TR></TABLE>
No, the fuse in the fuse panel that feeds the free spade terminal.
Check on the top of the fuse panel - there should be 4 male spade lugs - check with your meter for power on these:
one is Hot constant from battery, one is hot with ignition on, one with your lights on (this is the one you want!) and one with the key to ACC posn.
Connect the white wire with a spade terminal to the one that is hot when your light switch is on & you're gold!
Old Oct 25, 2004 | 08:35 AM
fcm's Avatar
fcm
Old Fart
Default Re: HELP! VIPER 550 ESP lighting issue (D'Ecosse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D’Ecosse &raquo;</TD></TR><TR><TD CLASS="quote">
Connect the white wire with a spade terminal to the one that is hot when your light switch is on & you're gold!</TD></TR></TABLE> No , I ment the fuse on the white parklight output wire of the alarm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoLOW916 &raquo;</TD></TR><TR><TD CLASS="quote">i dont recall seeing a fuse connected to the white wire, but ill check that.</TD></TR></TABLE> You will find it about 3" from the alarm brain, BTW do the parklights work when you turn on the lights? if not , then do the above as D'Ecosse says, but a blown parklight fuse, [the one that powers the free plug] will not keep the alarm from flashing the parklight as the alarm will supply the power 94
Old Oct 25, 2004 | 03:51 PM
thanks for da helppppp!! i fixed it, it was parklight fuse!
Old Oct 26, 2004 | 04:56 PM
Proper's Avatar
So if you connect the parking light wire from your alarm with a female spade connector to the male spade at the fuse box it will flash your lights when arming and disarming?
Old Oct 26, 2004 | 05:40 PM
Default Re: HELP! VIPER 550 ESP lighting issue (Proper)
yep das exactly how my alarm works
Old Oct 27, 2004 | 07:26 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Proper &raquo;</TD></TR><TR><TD CLASS="quote">So if you connect the parking light wire from your alarm with a female spade connector to the male spade at the fuse box it will flash your lights when arming and disarming? </TD></TR></TABLE> Yes they will , and you can use it as an output at the same time, say if you add a set of fog lights to the car, use it , through a switch, to trip the relay for the fogs, that way you can never forget and leave the fogs on. 94
crxaddikt
Audio / Security / Video
Jun 7, 2011 05:04 AM
skrewdriver88
Jan 25, 2006 05:43 AM
GSR_Jamee
Mar 8, 2005 02:32 PM
saywhat
Feb 15, 2005 07:43 AM
Synergy001
May 31, 2003 10:40 PM
