Help with TV tuner
Old Mar 11, 2002 | 08:12 AM
justagsr's Avatar
Default Help with TV tuner
I installed a DVD player with a TV tuner. Now the problem I have is that the TV tuner has no signal. I know I didn't plug in the wire for the TV signal. Where do I plug in the wire for signal? Suggestions please.
Drop me a line at:
mlself@csg.net
[Modified by CivicRacerGSR, 11:12 AM 3/11/2002]
Old Mar 17, 2002 | 12:42 PM
integradmb's Avatar
Default Re: Help with TV tuner (CivicRacerGSR)
I am not completely sure but I think they hook the wire up to the rear windshield to get some sort of reception but if you have tinited windows it may not be too clear
Old Mar 17, 2002 | 01:27 PM
3RROR404's Avatar
what kind of equipment are you using?! I'd say check your connections for the tuner's antenna, may be loose or disconnected since the new install.
Old Mar 18, 2002 | 05:28 AM
justagsr's Avatar
Default Re: Help with TV tuner (3RROR404)
Thanks for the help. I'm checking everything out right now.
By the way, the equipment that I have is a Clarion DVD player and a Pyle in-dash tv tuner. I think I figured out the problem so everything should be all good.
Riptide101
Audio / Security / Video
Sep 17, 2007 01:39 PM
j_kevin_ca
Oct 26, 2006 05:52 PM
JRT2002
Apr 6, 2004 10:44 AM
RAWbertCuBus
Sep 19, 2003 07:02 PM
