HELP system problem
Old Aug 11, 2005 | 09:11 AM
Luward's Avatar
Default HELP system problem
for some reason. my sub are making some bump sound when i turn off my volume. it sound like when i turn off the volume its making a vibrating noise. and when i turn off my car it makes this loud bump sound. can someone tell me whats the problem. let me know thanks
Old Aug 11, 2005 | 09:47 AM
mrdeadman's Avatar
They let me pick
Default Re: HELP system problem (Luward)
mine does that too. maybe it's just built up power being released or something. idk.
Old Aug 11, 2005 | 10:25 AM
Luward's Avatar
Default Re: HELP system problem (mrdeadman)
it was working good for awhile untill one day it started to do it. HELP if someone know
Old Aug 11, 2005 | 10:38 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">mine does that too. maybe it's just built up power being released or something. idk.</TD></TR></TABLE> As goofy as that sounds, kind of.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luward &raquo;</TD></TR><TR><TD CLASS="quote">it was working good for awhile untill one day it started to do it. HELP if someone know</TD></TR></TABLE> Check the ground on you amp, and the HU, even if they look good, remove them, make sure they are clean and reground them. 94
Modified by fcm at 8:06 PM 8/11/2005
Old Aug 11, 2005 | 03:57 PM
NiPBoi's Avatar
Default Re: HELP system problem (fcm)
its ur remote wire...are u using ur stock deck???...because if u are then they used ur ignition wire or some other wire that works kinda like a remote but not to par wit one...if not u should get ur remote wire checked...
Old Aug 12, 2005 | 03:30 PM
Luward's Avatar
Default Re: HELP system problem (NiPBoi)
im using a pioneer deh-6600. could it be possible some wire touching?
94civicEX
Jul 2, 2008 03:53 PM
90hatchbaby
13
Apr 13, 2007 08:04 PM
__oversea
Nov 23, 2006 08:00 PM
E36 Guy
13
Feb 12, 2006 05:47 PM
taffetawhitegsr
Aug 16, 2004 03:36 PM
