help with speakers
Old Jul 9, 2005 | 05:42 PM
kingrd's Avatar
Default help with speakers
first off..im not too good with this...thats why i need the help. i have a 97 gsr, and im replacing the stock speakers. there is just a plug for the stock speaker, and u can just pull them apart. For my new speakers, there are spots that have to be soldered on. How do i remove the plug, and basically, what do i do!!!
Old Jul 9, 2005 | 07:25 PM
kcem1's Avatar
Default Re: help with speakers (kingrd)
cut the plug off and get some speaker terminals that you can crimp on.
Old Jul 10, 2005 | 08:17 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kingrd &raquo;</TD></TR><TR><TD CLASS="quote">first off..im not too good with this...thats why i need the help. i have a 97 gsr, and im replacing the stock speakers. there is just a plug for the stock speaker, and u can just pull them apart. For my new speakers, there are spots that have to be soldered on. How do i remove the plug, and basically, what do i do!!!</TD></TR></TABLE> If you look close you will see how to "depin" the metal term. from the plastic plug, you can even use the oem term., [the neg. (-) one is a little big and will be loose] I just plug them in and solder them a little. you can also get a speaker wire adpt., it will plug into the Honda/Acura plug and has aftermarket term., "slots", [male flat spade connectors .124" for the neg. (-) and .25" for the pos. (+)] or you can as others have suggested, just cut the plug off and solder the wires right to the speaker term. or solder a short piece of the wire that comes with the speakers, [ the speaker term. end ] to the oem wire 94
creator1322
Oct 17, 2008 03:14 PM
turnsignalandy
Audio / Security / Video
Dec 15, 2006 10:48 PM
kingrd
Jul 9, 2005 08:20 PM
NavyHonda95
Oct 26, 2004 08:37 AM
black2001gsr
Mar 10, 2003 06:04 AM
