help needed BAD w/in the hour!
Old Mar 5, 2010 | 08:39 AM
91civic4drswapd's Avatar
New User
Default help needed BAD w/in the hour!
I have a 91 civic w/a d16z6 swap & its completely converted to obd1 except for fuel injectors. My question is im having remote start installed & im not sure what color the wire is that goes to the starter.please help my appointment is in an 1 & 15 min. Also could i just tell the installer to use a wiring diagram from a 95 civic? PLEASE HELP A.S.A.P thank you
Old Mar 5, 2010 | 09:29 AM
nsxxtreme's Avatar
Default Re: help needed BAD w/in the hour!
black white white stripe or balck with yellow strip I dont recall.
Go to the12volt.com and download your wiring for your specific car.
If your talking about the wires under the hood then good luck with that I'm not sure alarm diagrams will be of any help. Your best bet is to buy an auto repair manual for the wires that you got with your swap and check the back of the book the wiring diagrams will be there.
Old Mar 6, 2010 | 10:01 AM
fcm's Avatar
fcm
Old Fart
http://bulldogsecurity.com/diagrams/...16309&MakeID=3
I am assuming the ign. switch wiring has not been changed
Only wiring under hood, [other then hood pin and possible siren] that is needed is tach, use an injector. 94
beana
Jun 15, 2009 10:00 AM
JDMLRG209
Mar 7, 2009 10:49 AM
Spaceballsthelunchbox
Welding / Fabrication
Jun 21, 2005 06:04 AM
JSpecwest
Dec 24, 2001 06:34 PM
