help me engine start!
Old Nov 27, 2006 | 01:55 AM
smoking666's Avatar
Default help me engine start!
my sister gave me this engine start alarm for my 97 prelude auto. in the papers that came with it, it says 98+ preludes have a transponder. my friend tells me that i need something to bypass it to make the engine start thing work.. can someone explain who what i need to make engine start happen. thank you
Old Nov 27, 2006 | 04:32 AM
B18C_EJ8's Avatar
The papers and your friend are both correct.
You need an immobilizer bypass module. There are universal units that require a spare key and programmable units that do not require a key. Do a search. It's been discussed before.
Old Nov 27, 2006 | 10:26 AM
fcm's Avatar
fcm
Old Fart
Default Re: help me engine start! (smoking666)
Are we missing something here guys, 98+ ludes have transponder keys, [immobilizers] you have a 97 Prelude, your car does not need a bypass module, it does not even need a 2nd ign. starter or acc.... http://www.directwholesale.net...eID=3 it is a very easy car to do an alarm/remote start on. 94
Old Nov 27, 2006 | 11:15 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Are we missing something here guys, 98+ ludes have transponder keys, [immobilizers] you have a 97 Prelude, your car does not need a bypass module</TD></TR></TABLE>
Doh!! Didn't see that!
Old Nov 27, 2006 | 11:25 PM
smoking666's Avatar
cool... is there a way to double check to make sure of this tho ? my car is the same style as a 01 so how do i tell the difference ?
Old Nov 28, 2006 | 12:28 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Here is the wire diagram for you car, Don't go off the look of the car. That would be straight . The 94 thru 01 tegs have the same body style. And only the 99 and up have the immoblize. Just because its the same body style does not mean its wired the same. It may have the same harness but some things have been changed. Here look for yourself
1997 Honda Prelude Security Information
Constant 12V+ White Ignition Switch Harness
Starter Black/Red or Black/White Ignition Switch Harness
Ignition Black/Yellow Ignition Switch Harness
Ignition 2 White/Black Ignition Switch Harness
Accessory Yellow Ignition Switch Harness
Tach Blue Passenger's Strut Tower 2 Pin Connector
Neutral Safety Wire Blue/White (-) Gear Select Switch
Brake Switch Green/White Brake Switch
Trunk Pin Orange/Silver Dots Passenger's Kick at Gray Connector
Parking Lights Red/Black (+) Empty Slot in Fuse Panel
Head Lamp Blue/Red (-) 8 Pin Blue Connector behind Fuse Panel
Door Trigger White/Black Driver's Kick Panel Connector bottom. of Fuse Panel
Door Lock Black/White 2 Pin Gray Connector Driver's Kick Panel
Door Unlock Blue/Orange (-)
Horn Wire Blue/Red (-) Steering Column
Windows Up LF=Red/Blue, RF=Blue/Yellow in Door only
Windows Down LF=Red/White, RF=Blue
Old Nov 28, 2006 | 03:13 AM
B18C_EJ8's Avatar
The way you tell if you've got the transponder is when you start your car or turn it off, is there a little green key flashing in your cluster somewhere? If so, you've got it. No green key, no transponder.
Old Nov 28, 2006 | 05:06 PM
smoking666's Avatar
Default Re: (B18C_EJ8)
o ok..well my 97 has a transponder then
Old Nov 30, 2006 | 06:02 AM
fcm's Avatar
fcm
Old Fart
Default Re: (smoking666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smoking666 &raquo;</TD></TR><TR><TD CLASS="quote">o ok..well my 97 has a transponder then</TD></TR></TABLE>Well then it's the first 97 I have seen or heard of that has one, are you sure it's a 97, what is the date of manufacturer, [drivers door VIN sticker]?94
Old Dec 7, 2006 | 09:16 PM
smoking666's Avatar
Default Re: (fcm)
manufactured 10/96 also has a tracking sticker near that stick also..
im pretty sure its a 97.. inless the pink slip lies
Old Dec 8, 2006 | 04:58 PM
fcm's Avatar
fcm
Old Fart
October 1996, it could well be a 97, and you will need a bypass module. 94
GazeR_
Honda CR-V & Element
Mar 11, 2018 08:58 PM
RRexach
Jan 1, 2018 05:20 PM
cloud17
Audio / Security / Video
Dec 20, 2010 11:41 AM
JunY
Honda S2000
May 28, 2007 06:49 AM
MugenHonda
Apr 4, 2006 12:38 PM
