Help installing keyless entry
Old Oct 29, 2003 | 01:16 PM
95excoupe's Avatar
Default Help installing keyless entry
I looked by my fusepanel and there are thousands of wires...I need to know what plug and where to find all the wires to hook up keyless in a 95 civic ex it has power locks and all so I thought it would be easy. Please help so I dont kill myself for being an *** and buying this without realizing how much it sucks to install...Oh its a black widow kit and its just keyless no alarm or anything I just want it to unlock my doors and maybee flash the corners so I know it did it, nothing special. Thanks
Old Nov 1, 2003 | 02:01 AM
binkster's Avatar
Default Re: Help installing keyless entry (95excoupe)
Good luck,, i just had to reinstall mine on a 96 ex coupe.... Cant really help you though... just here for moral support... good luck. mine was basically plug and play.. my biggest problems were finding the fuses that I blew in the process..
Old Nov 1, 2003 | 05:20 AM
rjr162's Avatar
Default Re: Help installing keyless entry (binkster)
check around in the kick panel area for a two pin grey plug not hooked to anything. Most honda's have this plug if they came with power locks (up to a certain year in the 90's anyhow.. I think it was like 98?). Anyhow, this plug interfaces with the lock and unlock relays. To test it, hook your red lead of a multimeter to a +12 volt source, and then put the black lead up against one of the contacts in the plug you think might be the one i'm talking about, and then lock and unlock your door. Either locking, *OR* unlocking, should make the pin you're touching complete the circuit and your meter will read +12. When it does, look at if your locks are locked, or unlocked. Connect the approriate wire from your alarm brain up to that wire. The other wire in the plug will be the opposite (so if the first wire was lock, the 2nd will be unlock). Just make sure your alarm brain has negitive doorlock outputs.
also check out that
http://www.installdr.com
Old Nov 1, 2003 | 06:58 AM
rjr162's Avatar
Default Re: Help installing keyless entry (rjr162)
LOCK
Green/white In driver's kickpanel**
**THIS wire can also be found at the factory alarm harness below the radio.
UNLOCK
Green/orange In driver's kickpanel**
t0ny
Nov 14, 2009 05:47 PM
96electronH
Audio / Security / Video
Jun 28, 2009 04:37 PM
whitelightning
Jan 15, 2007 05:55 PM
