help installing Compustar 2w900fmr-as
This is going into my crx. Its a CompuStar 2W900FMR-AS. I found most of where the wires run to but there are some wires where I'm not too sure where they go.
I have done some simple/basic alarm installs before but not a remote start before. Before you say, why a remote start on a manual, its because i'd like my car to be all warmed up by the time i finished getting ready in the morning.
CN1 (CONNECTOR 1)
1: (+) 12V Constant = WHITE/BLACK (+) IGNITION SWITCH HARNESS
2: Parking lights = RED/GREEN (+) AT HEADLIGHT SWITCH
3: (+) 12V constant, Prewired relay for 2nd ignition, acc or starter =?????
4: Accessory = YELLOW (+) IGNITION SWITCH HARNESS
5: Starter kill/Anti-Grind =??????
6: Starter = BLACK/WHITE (+) IGNITION SWITCH HARNESS
7: Ignition = BLACK/YELLOW (+) IGNITION SWITCH HARNESS
8: Ground = ground
*im not sure where any of these wire leads to*
CN2 (CONNECTOR 2)
1: (-) Light Output =?
2: (-) Status Output =?
3: (-) Ignition Output =?
4: (-) Accessory Output =?
5: (-) Starter Output =?
appreciated with any helpful info. Thanks J.
CN1 (CONNECTOR 1)
8: Ground = ground
CN2 (CONNECTOR 2)
superhatchbackbros
Audio / Security / Video
May 17, 2009 10:51 PM
dafuzzbudd
13
Oct 4, 2008 03:52 PM
