HELP!!! Installing 6.5's in front need help
Old Apr 21, 2003 | 01:45 PM
Nader_D's Avatar
Default HELP!!! Installing 6.5's in front need help
hey, im trying to get the stock mounting bracket off and i cant reach the last top left screw, how can i get to it? and if i have to take off the door pannel, how do i get the window roller off so i can take the pannel off? thanks
Old Apr 21, 2003 | 02:12 PM
t0p_sh0tta's Avatar
Default Re: HELP!!! Installing 6.5's in front need help (Nader_D)
There is a little "C" shaped clip where the window crank meets the door. Pop that off by puhing it off, sometimes they are a PIA. I've used forks with the middle teeth missing to get it off, if that helps. You will have to remove the door panel.
Old Apr 21, 2003 | 03:50 PM
cd5_2NR's Avatar
Default Re: HELP!!! Installing 6.5's in front need help (t0p_sh0tta)
yup...theres a little clip there...you could get it with a flat head too...
JasonYo
Jan 24, 2011 02:00 PM
turbob16ef
Oct 4, 2005 02:55 PM
cd5_2NR
Mar 12, 2003 12:27 AM
babyviper97
Jan 10, 2003 05:14 AM
blkonredcivic
Oct 9, 2002 05:18 AM
