help, how to install amp for mid's
Old Apr 6, 2008 | 09:30 PM
tienzien's Avatar
Default help, how to install amp for mid's
Hi, i know the basic of wiring amp and sub. i decided to run a second amp for my mid's because there are too much bass. i put on a distribution block for the power, run the output line from the first amp into the input line of the second amp, and got it up and running. now my problem is that is only produce bass and no sound on my mids. if you have any ideas what might be the problem or the proper way to install, please help me. thanks
Old Apr 7, 2008 | 02:40 AM
B18C_EJ8's Avatar
Default Re: help, how to install amp for mid's (tienzien)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tienzien &raquo;</TD></TR><TR><TD CLASS="quote">run the output line from the first amp into the input line of the second amp,</TD></TR></TABLE>
I have no idea what this means.
Old Apr 7, 2008 | 05:59 AM
fcm's Avatar
fcm
Old Fart
Yes it is a little confusing, I assume you mean you ran RCAs from the output/bypass of the sub amp to the new amp, [high-pass], but you did not mention that you connected any speakers to the new amp.
We need more info....
Make and model of your HU?
Make and model of your sub amp?
Mame and model of the new amp?
A clearer discription of how things are wired would also help. 94
Old Apr 7, 2008 | 09:16 AM
tienzien's Avatar
sorry for the vague detail, my deck is an alpine CDA-7863. first amp is kicker 750/1 and sub is a 12" kicker L7. second amp is a rockford fosgate 50x2. when i say run the output line into the input, i mean rca's output from 1st amp to 2nd amp input. yes i did connect the mid's to the 2nd amp and my problem is it only produces bass and no sound. my mid's are pioneer 2 way speaker if thats any help by the way. thanks.
Old Apr 7, 2008 | 11:15 AM
fcm's Avatar
fcm
Old Fart
Default Re: (tienzien)
"Either input method will provide a low-level output signal at the RCA output, which effectively passes the audio signal to another amplifier"
^^^ from the Kicker ZX 750.1 owners guide.
You will have to run another set of RCAs from the HU, [front preamp output] to the new amp, your sub amp is connected to, [or should be] to the HUs sub output, the Alpine CDA-7863 has, among other things, a high/low-pass x-over built in, use them instead of the ones on the amps. 94
Old Sep 25, 2008 | 04:25 AM
Wkd's Avatar
Wkd
Just do the other way. Set the preset "second amp" as the first one. The Fosgate Punch 50x2 is a wonderful amp, and has the "audiophile bypass", which allow you to link RCA output from it to a second amp without change original settings of the signal.
In my car, I have this Punch 50x2 as the first amp (for midbass, midrange and tweeter), and use its "audiophyle bypass" RCA to a second amp, a Fosgate Punch 200.2 for the bass (one 12 inch sub).
Hope to have helped.
VTECth1s
Audio / Security / Video
23
May 26, 2011 12:10 PM
gunnerman
20
Oct 9, 2007 08:39 AM
PiNoYxRaCeRxRH88
11
Nov 26, 2005 10:35 AM
shyboy817
Aug 12, 2004 11:30 PM
integra-modder
Jan 1, 2003 02:24 PM
