HELP! ELECTRICAL PROBLEMS
Old Aug 23, 2004 | 09:53 PM
RCHB's Avatar
Default HELP! ELECTRICAL PROBLEMS
WHATS UP I JUST INSTALLED A DECK IN MY FRIENDS OLDER MODEL PRELUDE.. THE DECK WORKS FINE BUT EVERYTIME I PUT THE E-BRAKE DOWN THE HAZARD LIGHTS BRIGHTEN UP ON THE CONSOLE, WHEN I JUSE THE SIGNAL THE THERMOSTAT GOES ALL THE WAY TO HOT, BASICALLY A LOT OF LIGHTS SHOW UP WHEN NOT NEEDED. AGAIN THIS HAPPENS WHEN I PUT THE E-BRAKE DOWN. ANY HELP WOULD BE GREAT, THANKS
Old Aug 23, 2004 | 11:47 PM
tjohnson329's Avatar
Default Re: HELP! ELECTRICAL PROBLEMS (RCHB)
sounds like cables arn't grounded god or you have a couple cables grounding on eachother. check to ake sure your fuse box has a solid ground and is secure.
wuhthafunk909
Aug 22, 2006 09:07 AM
