HELP for DVC sub
Old Oct 28, 2002 | 02:45 PM
slo95cx's Avatar
Default HELP for DVC sub
Alright, so I'm no audio genius but i just got an ALUM15Q from Audiobahn and I'm not sure how the wriring set up works... how exactly do i use the ++/-- inputs?
I'm running this from a bridged 600W Kenwood amp. ANY information is appreciated since I'm pretty much only benefitting from half the power right now. Thanks.
Old Oct 28, 2002 | 03:37 PM
2dark2bslow's Avatar
Default Re: HELP for DVC sub (slo95cx)
it depends on the ohm load of the voice coils. Is the sub a dual 2,4 or 6...should say on the sub somwhere.
get that and we can go from there if you still need help.
josh
Old Oct 28, 2002 | 10:51 PM
SpdNvy's Avatar
Just as 2dark2bslow has said, which version is it?
A) Audiobahn AW1500Q 15" Dual 4-ohm Voice Coil Component Sub Dual-voice coils • non-pressed pulp cone • foam surround • 50-800W RMS total power range • 18-500 Hz frequency response
B) Audiobahn AW1506Q 15" Dual 3-ohm Voice Coil Component Sub Dual voice coils • stamped aluminum cone • 2"-thick foam surround • 50-1,300W RMS total power range • 18-500 Hz frequency response • chrome basket
From that you can decide which way to go:
ie...
Wiring Option #1 (1) 2 ohm DVC Spkr = 1 ohm Load
(+) On Amp to 1st (+) on Sub then 2nd( +) on Sub
and likewise (-) On Amp to 1st (-) on Sub then 2nd (-) on Sub.
Wiring Option #2 (1) 2 ohm DVC Spkr = 4 ohm Load
(-) On Amp to 1st (-) on Sub then the (+) and (-) left over get connected together.
Wiring Option #3 (1) 4 ohm DVC Spkr = 2 ohm Load
and likewise the (-) On Amp to 1st (-) on Sub then 2nd (-) on Sub
Wiring Option #4 (1) 4 ohm DVC Spkr = 8 ohm Load
If you need any other wiring assistance, try http://www.the12volt.com
[Modified by SpdNvy, 3:06 AM 10/29/2002]
BLUE EH3
Audio / Security / Video
Feb 4, 2006 03:03 AM
91DroppedHatch
Jun 20, 2005 02:57 PM
noob with an RS
Dec 20, 2004 02:35 PM
xJ.SLOTHx
Feb 14, 2002 11:12 PM
976
Aug 10, 2001 10:27 AM
