Help choosing upgrade.
fcm seems to know what he's talkin about.
lol. Also I'll say check out elemental designs http://www.edesignaudio.com I have used many of their products and they are great quality at great prices with a nice warranty to boot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WillEat4F00d »</TD></TR><TR><TD CLASS="quote">The Kenwood amp is okay right? Are there better alternatives out there for my needs? What other stuff would I need to get everything strait (wiring, etc.)? Should I resolder the rear tweeters if I add the sub and amp?</TD></TR></TABLE> Yes the Kenwood amp is OK, of coarse there are better alternatives, more then a few.
If installing an amp you will need interconnect, [RCA cables] and proper power wire with fuse and fuse holder, and some amp control lead, [20ga wire].
You do not want tweeters behind you.
94
94
Why do some recommend me getting a 4 gauge wiring kit then? This is what they say I should get: http://www.knukonceptz.com/pro...-AK44
Will it be different if I get the 8 gauge kit, or even 20 like you suggested?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WillEat4F00d »</TD></TR><TR><TD CLASS="quote">Why do some recommend me getting a 4 gauge wiring kit then? This is what they say I should get: http://www.knukonceptz.com/pro...-AK44
Will it be different if I get the 8 gauge kit, or even 20 like you suggested?</TD></TR></TABLE>LOL, the 20ga lead is for the amp control lead, it is not the power cable for the amp.
I said "proper power wire", you can use 8ga, if the power lead is going to be longer then 10-12 feet, use 4ga, but not that one, it uses set screws to connect power cable to the fuse holder, you want something you can use ring terminal on, something like this... http://www.scosche.com/efx.asp...PWFHI or this... http://cgi.ebay.com/AUDIOPIPE-...wItem then solder the ring terminals to the power cable and bolt them to the fuse holder, set screws are a poor way to connect a power lead.
94
94
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
I was not fond of that amp kit. I see some people hyping it up. The rca look real flimsy and cheap. The fuse holder looks like the ones I can get for 3-4 bucks and did not hold the fuse well. The member ended up just using the wire and trashing everything ese. You get what you pay for.
I'm thinking about this Stinger 8 gauge kit: http://cgi.ebay.com/Stinger-HP...wItem
Will that one do me fine for my needs? I'm still open for any other suggestions; not over $50 though, sorry. Remember, I don't want to buy anything separate, just the kit and everything should work.
It depends on how you want to set the system up. What about the back speakers? Run them off the headunit and amp the front. Yes you would need two pre outs. Front and sub. Most good headunits come front-rear-sub I don't know how you want to go
As I said, if it's a kit you want then the 4ga with the ANL fuse is the better one... http://www.knukonceptz.com/pro...-AK44
Although there would be an advantage having a HU with a sub output, [sub "volume" control] you only need one preamp, [RCAs] output to drive a 4 ch. amp in 3 ch. mode, most amps will have internal paralleling.
As mentioned, not hard to find a HU with sub out, and better HUs/brands will have up to 3 preamp outputs with one of them being a non fading, sub control output.
If you want to be able to adjust the subs output separately from the main volume you will need at least 2 sets of outputs, or a sub output, if you don't care and you just want to "set it and forget it" your HU only needs one set of outputs.
Alpine still makes a pretty good product.
$200 or lees will get you one of these... http://www.alpine-usa.com/US-e...tab=F
Another $30 and you get this... http://www.alpine-usa.com/US-e...-9883
94
94
s2kc's
Honda S2000
22
Dec 9, 2010 06:16 AM
Intercooler
Audio / Security / Video
Dec 10, 2004 10:28 AM
