HELP box size
Old Oct 16, 2005 | 01:50 PM
CRXb18Turbo's Avatar
Default HELP box size
Okay.. I'm looking about about .0625 FT3
Here the diamentions
It's a bass tube
10" round
to make .0625 ft3 how long does it have to be?
I try'd and my match is not matching up.
I got 15 1/2 inches long.
But the calculate i get is .625 ft3
vol=Pie X Radias^2 X height then divide by 1728. It's getting .625 ft3... Need .0625
Is my formula wrong??
HELP....
Old Oct 16, 2005 | 03:39 PM
fcm's Avatar
fcm
Old Fart
Default Re: HELP box size (CRXb18Turbo)
You need a box that is 6/100th of a cu ft? Ok......
.0625 cu ft x 1728 cu in =108 cu in, and a 10" tube has a radius of 5" so 5 x 5 =25 x 3.1416 =78.54 sq in, so 108 cu in / 78.54 = 1.375095492 so the tube would be just under 1.5" long 5x5=25x3.1416=78.54x1.375095492=107.9999999/1728=.0624999999 cu ft
Maybe you should check what size of box you need again. 94
Old Oct 17, 2005 | 12:44 PM
Default Re: HELP box size (fcm)
actually misprinted. I need .625 ft3
So is the formula V=pie x radias^2 x height then divide by 1728 to get ft3 ??
3.1416 x 25 x 14 = 1099.56 / 1728 = .636 ft3 ???
Old Oct 17, 2005 | 01:47 PM
fcm's Avatar
fcm
Old Fart
That sounds better, although you can get an exact length by changing your known volume, [.625cu ft to cu in] .625cu ft = 1080cu in, divide by area 78.54sq in and that would be 13.75".
Here is one more wrinkle, is .625cu ft gross or net volume, [does it include the displacement of the speaker? 94
Old Oct 17, 2005 | 02:57 PM
It's net.
so 13.75 - 14 would be good enough?
Old Oct 18, 2005 | 08:34 AM
fcm's Avatar
fcm
Old Fart
Yes in a sealed enclosure, 10% up or down is no biggy, but if it's net volume you will need to add the displacement volume of the speaker to the .625cu ft, that will give you the gross volume. 94
downtime1
Audio / Security / Video
Oct 6, 2018 03:05 PM
89hbcivicguy
Nov 17, 2004 04:16 AM
SoulSurfer
Feb 7, 2004 11:15 PM
Bilybobjef
Sep 29, 2002 08:36 AM
